First post, by B. Blaze
I'm currently trying to run Duke Nukem 3D via DOSBox ECE and am running into a DOS/4GW error. I have a couple questions? Can AWE32 be used in DOSBox and/or should I change the IRQ from 7 to 5? I'm thinking it's related to the audio settings not being quite right? Any help will be appreciated.
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Ask questions about ECE here: DOSBox ECE (for Windows & Linux)
I see you've already mentioned your issue there, so you'll just have to wait to hear back because this part of the forum is for what you call "deprecated" DOSBox. Thread closed.
