Reply 200 of 208, by astigmatism
- Newbie
Yes thank you. I have reviewed this blog before but nothing helpful stood out. Considering the amount of detail in it, can you be specific about which method you're referring to?
If "MTRRLFBE.EXE LFB WC" as a solution - I tried this but it had no effect.
If system.ini changes to limit Windows 98's "visibility" of usable RAM - I intentionally used 1GB on the Evga board to avoid doing this.
Keep in mind the Asus x58 board was behaving as expected and the Evga was not despite identical equipment and OS configurations. The BIOS settings described in that blog were specific to the board they used. There were many settings my Evga BIOS did not have so this blog isn't necessary a panacea for all X58 builds.
