Reply 520 of 890, by VDNKh
- Member
sirotkaslo wrote on 2022-01-27, 06:24:Hi, i'm having issues with one of the drivers needed for running win98se on 4coredual-sata2 r2.0. […]
i'm having issues with one of the drivers needed for running win98se on 4coredual-sata2 r2.0.After I install via 4in1 5.24a I get a device that can not start standard dual pci ide controller. I take it this is the sata controller? But its running in ide mode since xp install went smoothly. Does anyone have the needed driver?
thanks!
The SATA controller won't work in ACHI mode in 98 but it will work in RAID mode if you install the RAID drivers. RLoew's SATA patch might work but I haven't tried it on my R2.0. I can report that XP has the SATA driver (and all the other drivers for that matter) for that board pre-loaded in SP3, which is why it worked. I think you are better off using IDE on this board for 98 if you can.
If you want to set everything up with RAID drivers you can slipstream the driver into XP like I did here. I'm not sure how to do that in 98 but let us know if you figure it out!
henk717 also posted a custom 4in1 driver that is more compatible with 98SE, while it won't fix the issue you are having, it will install correctly and not leave a resource conflict like VIA's will.
Another note on the RAID driver for the 4CoreDual-SATA2 R2.0 board, if you have EMM386 loading it will hard freeze on the 98 splash screen if there's a device in RAID mode connected and the RAID driver is installed. This is relevant if you have some kind of SB16 emulation going on with your soundcard.
