First post, by nosuch
This is an NEC Ready 9716 which I have to say is one of the least convenient cases I've worked on. To replace the CMOS battery I had to remove the entire drive cage, and the floppy cable connector is inconveniently hidden behind the power supply 😀
I'm trying to mount 2 things in the 5.25 bays that are available. The top bay with a CD-ROM is unique as it has mounting screw holes with a standard pattern, so the CD-ROM was easy. The lower 2 bays however have large open areas where I would hope to find screw holes. If they were intended to be used with rails then it's a much larger rail size than I'm used to. The only other mounting option I can imagine is some kind of server-style rabbit ears - see the holes in the front pic.
Does anyone have experience with a system like this and have any advice? At this point it seems that if the ears approach doesn't work out I'll end up kludging something together. Maybe a vecro and sticky tape solution, or something 3D printed to fill the void space in the sides. Neither sounds great.
Reply 1 of 4, by Horun
Yes that uses special mount rails that would have a flange on the front part to screw into the case, had to find a few for an old (Dell/Gateway/Compaq ?) case once that would be similar but are much skinnier than what you need...
They would be shaped similar to the plastic one in the picture or be like the metal ones but much wider...
Reply 2 of 4, by nosuch
Thanks, now I know what I'm looking for!
Reply 4 of 4, by Horun
PC Hoarder Patrol wrote on 2022-05-15, 00:53:
nosuch wrote on 2022-05-14, 18:52:
As above, & same question covered in a previous thread - NEC Ready 9716 - drive bays??
heheee if my old brain was not going soft would have remembered that topic ;p
Good job !
