SMC (WD) StarCard PLUS (WD/8003S) Win3.1?
First post, by ThenZero
I have an SMC StarCard PLUS 8003S. Works fine in WFW3.11.
Is it possible to get it to work in Win3.1?
Are there drivers for it (I haven't found any)?
Could I somehow pull the WD80XX.DOS file from WFW3.11 and use it in Win3.1? How?
Edit: to clarify I'm asking if anyone knows of a packet driver for this network card for win3.1 specifically, not how to get tcp/ip working in win3.1 generally. Thanks!
Reply 1 of 77, by Grzyb
There's no native networking support in plain Windows 3.1.
You can only use the NIC via DOS...
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 2 of 77, by davidrg
IIRC Windows 3.1 (and 3.0) is networking aware, it just doesn't include a network stack - like with MS-DOS you've got to provide that yourself. Microsoft sold the Workgroup add-on for Windows. Novell had their NetWare client as well as Personal NetWare. Probably Banyan VINES and Artisoft LANtastic had some level of Windows 3.1 integration too though I've never actually seen either of those before.
The Workgroup Add-on for Windows is probably what you're after. Windows 3.1 + the workgroup add-on should be functionally equivalent to Windows for Workgroups 3.1:
1.75 MiB
1.68 MiB
Reply 3 of 77, by Horun
Some things maybe worth reading: https://jeffpar.github.io/kbarchive/kb/115/Q115940/
https://www.betaarchive.com/wiki/index.php?ti … _Archive/126746
probably easier to just upgrade to WFW 3.11
Reply 4 of 77, by ThenZero
Grzyb wrote on 2022-05-16, 00:32:
How would I go about doing that? Is there a packet driver for it for DOS?
I mostly just want to ftp to my LAN
Reply 5 of 77, by ThenZero
Horun wrote on 2022-05-16, 03:18:
I do have wfw3.11 on the computer currently. The problem is I can only find soundcard drivers for it for win3.1 😭 trying to get the soundcard and the nic working on the same operating system 🤣
Reply 6 of 77, by davidrg
I would have thought any sound drivers for 3.1 would have worked fine on 3.11. What sound card do you have?
If you want TCP/IP networking on DOS (including FTP), this is probably the best choice: https://www.brutman.com/mTCP/mTCP.html. There are network drive options for DOS too though they pretty much all want a Linux server of some kind to talk to for various reasons.
Reply 7 of 77, by Grzyb
ThenZero wrote on 2022-05-16, 03:23:
You need the following:
1. packet driver for your card - probably SMC_WD, from Crynwr
2. WINPKT, from Crynwr
3. Trumpet Winsock
4. some FTP client for Win16, WWW browsers should work as well
Reply 8 of 77, by ThenZero
davidrg wrote on 2022-05-16, 03:39:
It's a soundblaster ct4170. I tried installing under wfw3.11 but got no sound. Under win3.1 it works perfectly.
Reply 9 of 77, by davidrg
ThenZero wrote on 2022-05-16, 04:07:
Don't think I've ever had any difficulty getting similar age creative cards working under 3.11. You could try grabbing the latest drivers from Creative (click view all downloads at the bottom of the page for DOS/Windows 3.1x).
Reply 10 of 77, by ThenZero
davidrg wrote on 2022-05-16, 04:20:
I'll give that a shot, thanks
Reply 11 of 77, by ThenZero
Would you suggest starting with a fresh install or upgrading from the win3.1 install where the soundcard is already working?
Reply 14 of 77, by maxtherabbit
Grzyb wrote on 2022-05-16, 03:48:
You need the following: 1. packet driver for your card - probably SMC_WD, from Crynwr 2. WINPKT, from Crynwr 3. Trumpet Winsock […]
3. Trumpet Winsock
This. I just went through this process on my 286 running Windows 3.1 in standard mode.
The "internet.zip" located here:
http://www.k7tty.com/Utilities/Windows31/index.html
Should have everything you need except SMC_WD.COM that you can get from crnwyr
Reply 15 of 77, by ThenZero
Ok I gave this a shot and the packet driver seems to work and shows the right Mac address and settings, winpkt looks good, tcpman lets me set up the IP address but...it won't ping the router. When I turn on the trace it shows the Mac address for destination and source as all zeros.. What does that mean??
Reply 17 of 77, by Grzyb
First, make sure the packet driver matches your hardware, and is properly configured.
You can eg. try running mTCP with that driver.
Reply 18 of 77, by ThenZero
Thank you to everyone! I at least now can select whether to use the network card or the sound card (but not both...more on that in a sec).
I never did get SMC_WD to work, but I went back to the WFW3.11 installation where the network card was working and found a folder called "Packet" that had "PKT8000.COM" in it and THAT worked great.
Turns out there is SOME kind of conflict between the network card and the sound card because once I initialize the packet driver, the sound card won't work in Windows again after that. Any idea why that might be?
Here are the current settings of everything that is installed:
XTIDE card, I/O 0x300, 0xcc00
Sound card, IRQ 5, I/O 0x220
Midi I/O 0x330
SMC StarCard IRQ 3, I/O 0x280, Addr 0xD400
Also I'm getting random application lock ups now if I have mTCP on and sound going. I also tried using Trumpet Winsock and sound at the same time, and that caused the whole system to lock up.
Reply 19 of 77, by davidrg
Very strange.
I've no idea what the SMC StarCard Plus is - there doesn't really seem to be much out there on the internet about it. Even the archived version of SMCs website from 1996 doesn't seem to mention it. It calls the 8003-based cards the "Elite 16 Ultra" or "EtherCard Plus". The few 8003-based cards I've got are all very old 8bit ISA cards so perhaps even in 1996 it was too old for SMC to bother writing about on their website.
I've got the Elite16/EtherCard Plus drivers archived here perhaps they may work better (check the README file for descriptions of the files). It may also be worth trying the newer drivers in ether.exe - the documentation claims the drivers for WFW at least support WD8003 cards.
