Reply 2900 of 3179, by IcySon55
 - Newbie
Sunoo wrote on 2022-04-30, 20:26:I think I found an issue with what you grabbed. For the amplifier, you have a TI TPA152DR, but that seems to have a completely different pinout than the MS6308 or TDA1308 specified. Unless I'm mistaken, the STM TS482IDT should be pin compatible though, and appears in stock at Mouser. Not sure if anyone has a better suggestion though.
Thanks for the info and suggestions everyone!
I kind of want to be consistent with the part sources. So going with the TS482IDT, does STM also make a compatible OpAmp to replace the TI that I have on there now?
In other news, a friend of mine isn't making use of his soldering tools, so he's going to let me borrow them indefinitely for my projects! A soldering iron, multi-meter, solder, flux, and even some practice stuff!
Edit: They sure do! https://www.mouser.ca/ProductDetail/STMicroel … Kv5CLV5lQ%3D%3D
