First post, by keropi
- l33t++
Hiya!
let me present you the latest addition to the hardware clones lineup of unobtanium things 🤣
This is a fully-fledged AdLib GOLD clone reverse engineered by JimWest from his original card.
It works with the original AdLib Gold drivers and everything works and sounds like the original card.
There only 2 things that got cut off from the clone because they made no sense to add since nothing was released for them: the propriety CD-ROM and MODEM interfaces.
These functions are only added to the point where the tests and driver checks pass.
Everything else is implemented 100% and functions identical to the original card.
The clone (as expected) works with the original GOLD drivers:
There will be a limited run of this card , complete ready for use with the Surround Module and a bracket.
Just like the original every component on the card is expensive and of premium quality.
We have not yet secured all needed parts - but the most important ones like the old Yamaha/Analog Devices and Philips chips are all bought .
This has been worked in the past few months but now it is finally in the point where nothing more can be added or fixed so it was finally time to show it 😀
So check this space for future announcements , as usual one will be able to go to pcmidi.eu and express interest to buy the card there - once it's dedicated page gets created and everything is finalized!
Thanks for looking! 😀
