Reply 20 of 22, by bofh.fromhell
- Oldbie
Mitsa wrote on 2022-05-23, 08:06:Hello all!
I have in my hands the Victor V486MT/33. Boots ok but need setup. My problem is that can’t see an AT keyboard. No led flashing on any AT keyboard i plug in. You know the solution please? Have to do with the key switch at front panel, or maybe with Dallas battery. Or it is something else?
Thank you very much
It has to be unlocked or the KB will not work.
Well you can bypass the switch obviously.
Also mine did not work properly without a fresh cmos battery.
