Strike commander
First post, by hawk83
Now strike commander finally works, but I am having joystick problems.(I have a Logitech extreme 3d pro). I have tried several times to calibrate the joystick in the game, but it doesn’t change. The plane keeps rolling around like the joystick is totally uncalibrated. How do I fix it?? 😖
Reply 1 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
timed=false in dosbox.conf
1+1=10
Reply 2 of 5, by hawk83
Thanks! That did it! 😁
Just in case someone didn't understand: go to the dosbox.conf file and scroll down to joystick. Then change timed=true to timed=false.
Worked for me...
Reply 3 of 5, by Kemmster
I've got the same joystick but it isn't being recognised. There is no message to say that it's been loaded and when Strike Commander loads the joystick and the mouse don't work.
I was able to calibrate the joystick once but that was all.
Any suggestions?
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
if dosbox doesn't recognize the joystick (look in the status window) then you have to check your Operating system to see if it gets detected there
Water flows down the stream
Reply 5 of 5, by Kemmster
Sorry I meant to add this into my first post.
It's being recognised in Windows. I'm able to do a full calibration test and all the buttons including the POV hat are working.
