ChrisK wrote on 2022-05-25, 07:39:Does this fit into a regular socket when the components / dip-switches on the underside are mounted?
I have those sockets with s […]
I have those sockets with some larger caps or even temp-sensors mounted within the socket cavity in mind.
This adapter has to be soldered to the CPU pins right?
Any chance to integrate some tiny spring contacts for the necessary pins to avoid this step?
Something like this:
https://www.mill-max.com/products/receptacle/0531
https://www.mill-max.com/products/receptacle/5342 (may be too large for the pin spacing)
Click the link, there are links in OP to the other versions.
There is one that goes on the processor (pictured)
One that goes on back of the mobo
Small one that goes on back of mobo
And a full fledged voltage interposer. For older mobos with single plane.
For now yes, the processor mounted one it must be soldered. I may try and order a slightly smaller holed one and see if I can get press fit to work but this one needs to be soldered .
If it fits depends on the mobo.
A interposer adds more clearance though
Yeah, it might be possible to add something like that.
As for making it removable we already have a option though and it’s pretty easy to make. The interposer route.
However yes, for those tension fit pins spacing becomes a issue there is very little room to play with vertically or horizontally
.016” is barely in spec for these pins. Is there a smaller one?
Post in the processor tweaker thread and I can look into it further to be sure.
Here is the interposer style
Btw, I got two tillamook 233s now which I tested with the motherboard tweaker they work with l2 and even have the 4x setting…😳
