Reply 20 of 25, by FeedingDragon
- Oldbie
Well, if it can't be done, then it can't be done 😀 I'll live....
Feeding Dragon
Feeding Dragon
It can be done with DOSBox-x, AFAIK
Since DOSBox can install win9x with HDD image, then a DOS image is definitely working, either with a HDD image or floppy image. Actually I've done that with a win9x floppy boot disk image.
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
crazii wrote on 2022-06-29, 02:32:Since DOSBox can install win9x with HDD image, then a DOS image is definitely working, either with a HDD image or floppy image. Actually I've done that with a win9x floppy boot disk image.
Last time I tried to get win9x installed under DOSBox it failed miserably since DOSBox itself doesnt have the required support for Win9x to function, has this changed in the latest versions ?
Oh noes, the cap let the shmooo out 😁
TrashPanda wrote on 2022-06-29, 02:51:crazii wrote on 2022-06-29, 02:32:Since DOSBox can install win9x with HDD image, then a DOS image is definitely working, either with a HDD image or floppy image. Actually I've done that with a win9x floppy boot disk image.
OK My bad. I was using DOSBox-X, a third party fork pretty much like the SVN Daum fork. It's unstable anyways. The only benefit was Glide pass through that using host Glide wrapper to boost the Glide games but still it easily crashed and the rendering has stretched triangles for some games last time I played.
I've managed to do that in the late 2000s or early 2010s, I think.
It was with a specific version of Windows 95 and a homemade HDD image. I used bximage tool, I think.
If there's any interest, I can try to find out some details. Win95 version, commands in [autoexec.bat] section of dosbox.conf.
Stuff like that. Or, I'll just attach the whole text file.
I *think* I've got a backup copy of my setup..
