First post, by Kahenraz
I have mono sound from my Aureal Vortex 2 from the Duke Nukem 3D setup from within Windows. This is as tested with the VXD drivers. When the sound effects test runs, I hear both left and right channels from both speakers simultaneously.
Stereo works fine from my Audigy, so it's not the speakers.
Can anyone confirm?
Reply 1 of 10, by aaron158
witch driver version.
if its 2048 uninstall it and put on 2041.
Reply 2 of 10, by Kahenraz
I'm using 2041.
Reply 3 of 10, by Kahenraz
Using the exact same set of hardware and drivers, I get left and right channels working properly in a DOS window on Windows ME. But swapping to a drive with Windows 98, it's mono. Stereo works as expected under pure DOS.
This is very odd. I don't see what changing the operating system would have anything to do with it.
Reply 4 of 10, by appiah4
You are using the Sound Blaster Pro option in Duke3D not Sound Blaster 16 right?
Reply 5 of 10, by Kahenraz
That was it! I had it set to Sound Blaster 16, not Sound Blaster Pro.
Thank you. 😀
Reply 6 of 10, by appiah4
Glad to help. Cheers.
Reply 7 of 10, by Peter.Mengel
appiah4 wrote on 2022-06-02, 14:48:
Wait doesnt the SB16 offer Stereo aswell?
Reply 8 of 10, by Kahenraz
The Vortex 2 only supports Sound Blaster Pro.
Reply 9 of 10, by Gmlb256
Peter.Mengel wrote on 2022-06-02, 22:55:
Yes, but the SB16 isn't compatible with SBPro and vice versa (not really a big deal but it is something to take into account when configuring the sound card). The Aureal Vortex 2 only supports SBPro as Kahenraz said.
