First post, by butjer1010
Hi, i bought 486 motherboard A-Trend ATC-1442G, but someone torn out all the electrolytic capacitors from board. I don't know if the board is good or not, but i don't want to throw it away before i try to fix it. I would be very grateful if someone has the same motherboard, and if he could tell me what are the values of them, so i can solder new ones. I have found only one picture of this board on the net, but it is impossible to see the values. One of the picture is mine board, without capacitors, other one is the one from net, the one with all the capacitors.
Many Thanks in advance!
