First post, by boroda
Hi all. There is such a sound card. With initialization ESS IC everything is clear.
But how i can initialize the chip ICS2115V? I can't find the original drivers, and in general there are very few mentions of this sound card .
Thank you if anyone can help me.
Reply 1 of 5, by Babasha
JP5 on motherboards silk - set it to default 330H port and this is all you need)))
Need help? Begin with photo and model of your hardware 😉
Reply 2 of 5, by boroda
Unfortunately, but no. On all sound cards based on this chip, it requires a separate software initialization. Without it, games will not be seen GM on the 330h(or other)port.
Of course, i can take and try all inits from TB cards and other cards, based on the same chip, but what if someone has already gone through this path of a Jedi? )))
Reply 4 of 5, by boroda
I read this thread and already got the drivers there. )) But so far there are no guarantees, as with the drivers from TB. I will get the card in a few days, but i am preparing in advance. )))
