Reply 45080 of 57140, by Kahenraz
- l33t
Tetrium wrote on 2022-06-12, 19:11:But I could suggest you take a look at a Geforce4 MX 420 so that you can ask yourself what the heck you have been smoking 😋
That's too generous. A GeForce FX 5200 is even slower. Try and find a 64-bit one, if you are a true masochist. A GeForce 2 MX would probably be faster.
Gmlb256 wrote on 2022-06-12, 19:28:I have one of these GeForce 4 MX440 SE but it came with 128-bit memory bus and it wasn't bad except that mine had a unusually high memory clock that caused artifacts in certain video modes.
I had this issue as well with a used one that I bought recently. I was certain that it was bad memory (it was an issue with the memory, for sure), but the cause of the problem was actually bad capacitors.
Repair shops hate me. I fixed defective memory on my video card with this one neat trick.
I have tested the GeForce 4 MX series against the GeForce 2 Ultra and they are very competitive. I think a lot of the hate for these cards comes from someone having a crippled OEM version, the system they paired it with actually had a CPU that held it back or their system was low on memory and swapped too much during gameplay, or they just got one very late in the DirectX 8/early DirectX 9 era and tried to compare it with a GeForce 4 Ti or Radeon 8000 series.
For Windows 98 and anything DirectX 7, it is an excellent card.
