Reply 120 of 177, by Sphere478
Re: Adding 3.3v to pci
file.php?id=139772&mode=view
made this recently^
therefore naturally>
FREEWAY DESIGN FW Ti5VGF 1 3 3 V Adapter.zip
Anyone wanna check the measurements on this and prototype it?
if all looks good I can make a ultra version (this won't fit ultra)
Sphere's PCB projects.
Reply 121 of 177, by Kahenraz
That's a really nice board. I love the color.
What do you plan to use the iRam for?
Reply 122 of 177, by Sphere478
Kahenraz wrote on 2022-06-16, 17:14:
Just for cool factor really. And page file. But I have enough ram that the page file isn’t much needed.
Reply 124 of 177, by Kahenraz
That's pretty cool. I saw someone make something like this with some handsome looking orange wire, I think. I want to mod one of my boards with this some day.
Reply 125 of 177, by Sphere478
Kahenraz wrote on 2022-06-17, 00:43:
which board ya thinkin?
if this works well, I think I'll probably make one for the tyan S1564D and the freeway ultra
Reply 126 of 177, by Kahenraz
Probably my ASUS P5A, since that's the same one that I'm doing to add your CPU mod to.
I would have modded one of my Intel AN430TX boards, as I have a small collection of them. But they already have +3.3V on the PCI slots. It's also a Socket 7 board, so this was very surprising. I do want to CPU mod this one though.
Reply 127 of 177, by Sphere478
Kahenraz wrote on 2022-06-17, 03:12:
which revision? I'm assuming 1.05-1.06? the tweaker has a WT/WB mod for those.
I have a 1.04
I had a 1.06 but it sucked 🤣, ditched it.
Reply 128 of 177, by Kahenraz
Mind is 1.06, of course. 😜
Reply 131 of 177, by Kahenraz
Is there any advantage other than convenience to have it manufactured as a single PCB rather than individual parts that can be connected via a wire? If it is in pieces, it would be compatible with more boards.
Reply 132 of 177, by Sphere478
In the thread “adding 3.3v to pci” there is a single pci version.
I just noticed that I messed up the part where the 3.3v and 3.3/5v jumpers are. Oops 🤣 will fix that in next version. I plan on ordering red anyway so this was just a prototype to make sure it fit (red costs a lot more)
Here is the thread.
I haven’t ordered a prototype. If you want to, go for it, 😀 lemme know if it is okay or needs changes
Reply 134 of 177, by Kahenraz
It looks very professional!
Reply 135 of 177, by pentiumspeed
What you did is called modification board bodge. If I recall correctly, saves money not re-spin the board again, just install small bodge board either with jumpers or without.
Cheers,
Great Northern aka Canada.
Reply 136 of 177, by Sphere478
pentiumspeed wrote on 2022-08-07, 18:01:
Cheers,
🤔 cool. Didn’t know that term. I’ve heard of bodge wires.
Reply 137 of 177, by pentiumspeed
ideally, have some ground solder points on the bodge board and few SMD pads for capacitor or two next to each slot?
Cheers,
Reply 138 of 177, by Sphere478
pentiumspeed wrote on 2022-08-07, 23:46:
Cheers,
Not a bad idea.
Got a footprint in mind?
Prob easier to add the caps near the atx connector
Reply 139 of 177, by Sphere478
FREEWAY DESIGN FW Ti5VGF 1 3 3 V Adapterv3.1415.zip
okay, I have version 3.1415 of the pcb ready.
this is for the non ultra
the ultra version requires a modification to the atx location
-removed the vsb disconnect
-fixed the solder bridge configuration
-raised the atx location just a tad
-came up with a new edge cut layout
this is probably a final version, but currently I don't have a plan to prototype it anytime soon, lots of other stuff to do on other things in my life, so if someone wants to try it out go for it. just be careful.
eventually I'll modify this for the ultra
