MP32L - Lite version of MP32 : Pi based MT32 synth
Reply 160 of 171, by psychofox
Recived my MP32L last week, thanks for fast shipping dreamblaster!
There seems to be still total component blacout in world, everywhere i looked, no Raspberries available.
Has anyone tested MP32L on Raspberry Pi 2b? I did not find any info regarding MP32L on RP2b, so i decided to try out. So i dismantled my home server running on RP 2b. Prepared SD card and config file... and it kinda works! Boots up very fast, music sounds on General MIDI mode games very good. But older games, that support only MP32 sound kinda off. I mean like wrong instruments are used. Tested with old version MP32 and CM32 roms. Can anyone tell me where is the problem?
Reply 162 of 171, by psychofox
heckyeah wrote on 2022-06-19, 19:22:
Does your sound card support MPU401 intelligent mode?
No, i use a cheap-o cristal chipset based SB clone + softmpu. For comparision i have an original old version MP32 running next to MP32L.
Reply 163 of 171, by appiah4
psychofox wrote on 2022-06-20, 05:55:
Your issue sounds like SoftMPU is not working, or your computer is not managing to upload data to the MT32-Pi. This could be a problem with the USB MIDI interface you are using. What brand/model is it?
Reply 164 of 171, by psychofox
appiah4 wrote on 2022-06-20, 07:43:
I use it on my 486 PC at the moment , so no USB cable but MP32L directly hooked with Midi cable to sound card Joystic port.
I have also that cheap chinese USB MIDI cable somwhere lying around too, if i find it will give it a try.
Reply 165 of 171, by keenerb
I'm a pretty happy CM32-L owner at the moment.
One word of advice is that the small posts at the bottom of the case may need a little trimming, your Pi board should mount onto those holes, they aren't simply spacers. Took me a while to figure out why my case wouldn't go together properly.
Reply 166 of 171, by vutt
I have not yet found good quality screenshot of PCB in order to ID DAC chip on MP32L. Owners here, could you share this info. Product page is describing it as "High quality DAC" and that's all.
Reply 168 of 171, by Joakim
Hey
I've had this device for some time, it's nice and compact, but I have this wired thing happening. If I boot up a game, like quest for glory 1 (in mt32 mode) it start out ok and sounds correct to my ears, but if I push the second button from the left to change mode or what you call it, the sound becomes all messed up, notes are missing and incorrect. It does not get fixed by restarting the mp32l, I need to restart the game. I had this happen to me in lands of lore as well.
BR joakim
Reply 169 of 171, by Shreddoc
Joakim wrote on 2023-04-03, 19:59:
Hey
BR joakim
The same things would happen if you started playing a game with a real MT-32, and then, five minutes into the game, unplugged it and directly plugged in it's place (e.g.) a real SC-55. Changing modes on this device halfway through a playback, is the digital equivalent of doing that.
What you are hearing is normal. The music data (and/or the game code) often contains initialisation/patch/parameter events, which configure the synth for that particular game or song. Events of that type which have already occurred (e.g. settings initialised at the beginning of a game or song), will not persist when changing between MT-32 mode & Soundfont mode. It's as though you've switched on a fresh synth. It knows nothing of the previous notes or parameters that were played.
Furthermore, music data for the MT-32 is not entirely compatible with General MIDI, and vice-versa, so when changing modes halfway through a playback which was written for one-or-the-other, some forms of weirdness would be expected anyway.
Reply 170 of 171, by Joakim
Shreddoc wrote on 2023-04-03, 21:06:
The same things would happen if you started playing a game with a real MT-32, and then, five minutes into the game, unplugged it […]
Hey
BR joakim
Aha, thanks for the explaination, it makes sense. So in case I for some reason would like to switch mode to sc-55, I would need to do this before booting up the game?
Reply 171 of 171, by Shreddoc
Joakim wrote on 2023-04-04, 10:28:
Hey
BR joakim
Basically that's it. You may also need to run the game's setup.exe or equivalent, to choose between MT-32 and General MIDI.
Other combinations are possible, but as you've discovered, the results may sound a little unpredictable.
