Ct2800 - Speed sensitive
First post, by Riikcakirds
I was using a CT2960 (1996) (vibra with creative cqm) on a P-II 266 and everything I threw at it in dos7.1 worked, didn't have any problems with playing adlib music.
Switching to a CT2800 (because it has a genuine OPL3) and noticed a lot of the same games suddenly play adlib music completely garbled. i.e Curse of Enchantia. I can fix the adlib music on the ct2800 by slowing the computer down to 286 levels disabling L1 cache. The problem then is most games are too slow to play properly.
I never expected this with the CT2800, with it being a later model of the SB16 from around mid 1995. Is this just a drawback of any card that use a genuine OPL3 v creative CQM chips (which appear not to be speed sensitive). Seems a bit odd when there is only 1 year release difference between a CT2800 vs a CT2960.
Reply 1 of 7, by aitotat
Yes, real Yamaha OPL3 can be more speed sensitive than clones. And oldest games made for AdLib may not have any delays between writes so even a fast 486 is too fast for them. You can try Midito to add delays . But P2 is too fast for many games even if you get OPL working.
Reply 2 of 7, by Joseph_Joestar
Riikcakirds wrote on 2022-06-19, 17:41:
I have only used my Vibra (with real OPL3) on a Pentium MMX 166 and it had no speed issues there.
However, I did test a (PCI) Yamaha YMF744 on an AthlonXP 1700+ system at full speed, and it worked perfectly. No issues whatsoever with FM synthesis, even on older games from the early 90s.
Reply 3 of 7, by Riikcakirds
Joseph_Joestar wrote on 2022-06-19, 19:43:
What model vibra did you have? So it appears it's not opl3 v cqm but card related. I had heard about this speed sensitive problem years ago but thought it only affected sbpro and very early models (1992) of the sb16. Still, i'm a bit surprised a newer card like the ct2800 has this problem.
Reply 4 of 7, by Gmlb256
Yes, OPL3-compatible clones (CQM, ESFM, etc) responds to commands much faster than the real thing.
Riikcakirds wrote on 2022-06-19, 21:29:
Early Sound Blaster cards (except SBPro2) used real OPL2 chips, which was even more speed sensitive than OPL3. In addition to this, the DSP was also speed sensitive unlike the SB16 and later Creative ISA sound cards.
Reply 5 of 7, by Joseph_Joestar
I have one of those less common SoundForte Vibra varieties. It works fine with the latest SBBASIC.EXE driver from Creative's website.
BTW, check if your BIOS has an option called 16-bit I/O Recovery Time. Sometimes, setting this delay to a higher value can help with speed sensitive sound cards.
Reply 6 of 7, by Gmlb256
Joseph_Joestar wrote on 2022-06-20, 06:29:
The OP should be looking for the 8-bit I/O Recovery Time option instead, that one actually helps with sound cards having a real OPL3 chip.
Reply 7 of 7, by Joseph_Joestar
Gmlb256 wrote on 2022-06-20, 13:31:
Hm, I thought that was for 8-bit ISA sound cards (e.g. SB 2.0), but you might be right.
It won't hurt to check both options and see if either of them helps.
