Reply 20 of 24, by Stiletto
Xmodule999 wrote on 2022-03-15, 15:44:
Between ESS688F and ES688FC are there any differences?
Can you show us a picture of a chip labeled "ESS688F"?
ES688 datasheet: https://web.archive.org/web/20000815205749/ht … saaudio/688.pdf
Unfortunately this ESS datasheet does not define any sort of suffixes to the chip part number.
With other manufacturers, the suffix (-F, -FC, etc.) can mean anything from revision to timing to packaging type.
Best guess at the moment is it may mean chip package type, but I'll take a look at other ESS datasheets to see if they may have a generic suffix scheme defined somewhere.
Most likely, any sort of variation from ES688F to ES688FC will not matter to you at all. The big differences is usually when the actual number changes.
do the Fandango!" - Queen
Stiletto
Reply 21 of 24, by appiah4
I'm also not aware of any functional differences between revision suffices. And I've never seen a chip that wasn't FC to be honest..
Reply 22 of 24, by keenerb
Stiletto wrote on 2022-03-16, 00:17:
Can you show us a picture of a chip labeled "ESS688F"? […]
Little bit of a necro post, but I have an ESS688F chip on a soundcard in my collection. Would you like me to pull it out and get a good photo? I thought 688f was a pretty common chip actually.
Reply 23 of 24, by TrashPanda
keenerb wrote on 2022-06-20, 13:43:
I have a card with both ESS688F and ES968F on it . .no idea what the 968F chip does exactly.
