First post, by Quest for Glory
The topic says most of it.
I have an P2, with Audician 32 card, Roland Mt-32, that is conected to a Sc-88 Vl with the "through" conection. Running with Windows 98.
Most games I run with no issue. Quest for Glory 2, funn Mt-32 sound with messages in the display, same with Robin Hood, Castle of Dr. Brain.
But, when I try to run Larry 3 and Space Quest 3, I get no sound at all with Roland selected in the menu. Works fine with Soundblaster settings.
Also getting problem with DOTT, the sound start up with message and proper sound with the MT-32, but the game hangs 7-8sec in the intro, and the sound also hangs up.
The SC-88 works fine with Doom, Duke etc, so no issues there.
Really annoying that there is no problem with some games, but no sound at all with others.
Same problem with Win-98 dos mode, and if I boot in "true" Dos.
Anyone who can help me out? Wont play the games until I can play them with the Roland active.... :p
Reply 1 of 5, by Spikey
I could be wrong, so anyone correct me if I am, but this is an old game thing, possibly a conflict. While QFG2 is not VGA, it uses a different (later) version of SCI.
I think this utility will solve it: https://www.dosdays.co.uk/media/sierra/mt32sb.zip
"Just copy the MT32SB.EXE file to your game directory and run it. When prompted, enter you Sound Blaster's Address (usually 220H). If it worked, you should see a new file called MT32SB.DRV appear in your game's directory, and a new option in the INSTALL program's music card list called "MT-32 / SoundBlaster MIDI". If for any reason the INSTALL program fails to display this new entry (this often occurs), you will need to edit the file INSTALL.HLP manually, and add these 2 lines to the bottom:
\\MT32SB.DRV
MT-32 / Soundblaster MIDI
If not, let us know and we'll try something else. 😀
Reply 2 of 5, by root42
Quest for Glory wrote on 2022-06-23, 22:58:
The topic says most of it. […]
The Pentium 2 might be part of the problem. It might be too fast for some of the games. It would be gould if you could throttle it down or test with a slower PC.
YouTube and Bonus
Reply 3 of 5, by Quest for Glory
How about that...it worked 😁
Thank you 😀
root42 wrote on 2022-06-24, 06:50:
    796.83 KiB
Reply 4 of 5, by Spikey
Quest for Glory wrote on 2022-06-24, 13:59:
Thank you 😀
For people reading in the future, what solved your issue? 😀 Glad it is solved, either way.
Reply 5 of 5, by rad_sci_guy
Spikey wrote on 2022-06-24, 06:48:
I could be wrong, so anyone correct me if I am, but this is an old game thing, possibly a conflict. While QFG2 is not VGA, it us […]
\\MT32SB.DRV
I was also having issues running the game with MT-32 but this patch fixed it. Game runs great and the midi is coming out from the MT-32. I'm playing on an Pentium III 733 and the game speed is normal.
