First post, by keenerb
https://github.com/hkzlab/ES1868_ISA8
Seems like a neat project; does it work well? I know ESS1868 clones go for ~$20 USD on ebay, but I really enjoy using parts I put together myself.
No, but looks good and he has some other very nice stuff too. I think I would even prefer his ES688 as it's non-PnP, which makes a lot more sense IMHO for 8b ISA:
https://github.com/hkzlab/ES688_ISA8
Almost tempted to start ordering some PCBs - it's been too long 😉
I was thinking about this myself, but i cannot find a parts list for his cards.
If someone comes up with the BOM, I will order some bare boards.
Thanks,
Chris
I am compiling a parts list right now, if you'd like to help I'll send you an invite to the google spreadsheet and we can embark on this journey of discovery together. I've got es1868f chips coming this week.
I am wanting all my custom built boards to be purple.
I think the es1868f is the one to build. the board is smaller and the number of components doesn't look too daunting.
I don't know if I will be much help with the identification of the components, but I will be interested in the finished BOM
Thanks,
Chris
ahh i see now, he has all the parts in the gerber files.
I can work with that 😁
later,
Chris
dionb wrote on 2022-06-20, 23:36:No, but looks good and he has some other very nice stuff too. I think I would even prefer his ES688 as it's non-PnP, which makes a lot more sense IMHO for 8b ISA:
https://github.com/hkzlab/ES688_ISA8Almost tempted to start ordering some PCBs - it's been too long 😉
The 1868f on 16-bit ISA cards works great with the unisound driver, I'm pursuing that project myself. I was told the ess688 doesn't have a hardware MPU so that is less that ideal for my purposes also.
i think i have most of the bom figured out.
https://www.mouser.com/ProjectManager/Project … ssID=5b7c15b47a
i do not have the io plate, or jacks on this list
84TAVeRT wrote on 2022-06-26, 04:33:https://www.mouser.com/ProjectManager/Project … ssID=5b7c15b47a
Thanks a bunch. I have PCBs and ES1868Fs coming just as soon as china allows it...
I think there are some small surface mount components on the back of the card. I was unable to identify those.
on a side note, i found my original sbpro 2.0 in a drawer the other day 😁
84TAVeRT wrote on 2022-07-12, 18:55:I think there are some small surface mount components on the back of the card. I was unable to identify those.
I received my boards from jlcpcb yesterday, they look like pullup/down resistors to me. On another ES1868F board I have, there are several 473 SMD resistors performing what appears to be approximately the same function.
https://raw.githubusercontent.com/hkzlab/ES18 … S1868.kicad_pcb
(module Inductor_SMD:L_0805_2012Metric_Pad1.15x1.40mm_HandSolder (layer B.Cu) (tedit 5F68FEF0) (tstamp 60E998D6)
(at 304.165 150.241 90)
(descr "Inductor SMD 0805 (2012 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: https://docs.google.com/spreadsheets/d/1BsfQQ … dit?usp=sharing), generated with kicad-footprint-generator")
(tags "inductor handsolder")
(path /611FBE25)
(attr smd)
(fp_text reference L5 (at 2.54 0 180) (layer B.SilkS)
(effects (font (size 1 1) (thickness 0.15)) (justify mirror))
Text reference L5 (one of the pads) says it's an Inductor_SMD:L_0805_2012Metric_Pad1.15x1.40mm_HandSolder maybe?
I am making ES1868 clones following this project.
I have a question.
The two resistors, R28 and R29, are marked as 2.7 on the drawing.
Should it be 2.7Ω or 2.7KΩ?
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
486DX4-100EW, VI15G, 32MB, ARK1000VL, ES1868F
5x86-120GP, HIPPO-15, 32MB, Riva128, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
From the resistor band colours it looks like 2.7 ohms
Thermalwrong wrote on 2023-04-08, 01:48:From the resistor band colours it looks like 2.7 ohms
Thanks, I've got the PCB made to order and am about to try and build this card, have no prior knowledge of circuit design, it's a challenge.
zwrr wrote on 2023-04-08, 06:51:Thermalwrong wrote on 2023-04-08, 01:48:From the resistor band colours it looks like 2.7 ohms
It's good practise 😀 I put together a Gameblaster clone card from chipkin.ru (SoundTronix 1099) a few years back and it was a similarly harrowing experience, but worth it. That had a similar 'guide' to construction with mostly just silkscreen markings on the PCB to know what goes where.
Just checked the Bill of Materials on Mouser and it does say 2.71 ohms there so that should be it.
I just finished assembling this sound card and the same author's SAM2695 MIDI module.
after testing, the sound card and MIDI module work fine. It was a pleasant experience.
The test environment is:
Pentium 166
Asus T2P4 ver 3.10
16MB x2
S3 Virge/DX
ES1868 ISA 8bit + SAM2695 MIDI module
Use UNISOUND to configure sound card in DOS 6.22 system.
