First post, by Almoststew1990
I picked up a socket 7 system and it came with a QuickShot Pro16 Plus sound card.
From a quick Google older QuickShot cards were a exact copy/ rebrand of a Sound Blaster 2.0 card but this clearly isn't with it's opti and analogue devices chips. Has anyone used this card?
I can't actually get it to work. Both the s7 system and my usual Slot 1 system do not detect the card during post or in Windows. Can you notice anything broken or missing on it?
https://i.ibb.co/VvRTDSy/PXL-20220626-204432210.jpg
Reply 1 of 12, by Joseph_Joestar
Almoststew1990 wrote on 2022-06-27, 11:28:
That's a non-PnP card, so it's normal that Windows doesn't detect it automatically. You need to install the driver manually via Control Panel > Add New Hardware > Have Disk.
Try searching for a generic OPTi 82C928 driver. It will probably work fine.
Reply 2 of 12, by root42
There is a superb driver for DOS for the 929: https://github.com/JKnipperts/OPTi82c929_Driver
However I guess it won't work with the 928... So maybe try the attached one.
    928d&w.zip
    568.81 KiB
    40 downloads
YouTube and Bonus
Reply 3 of 12, by Oetker
Here's my notes on an Opti 928 chipset card:
This card wouldn't work properly under Windows 98 (seems it only had 3.1 drivers) and I couldn't get stereo sound to work under DOS. Worst of all, its gameport isn't MPU-401 compatible. I screwed up and bought the wrong card, apparently the Opti 929 is a fine chipset and Sound Blaster Pro 2/MPU-401 compatible, the 928 is not. It's more similar to an original Sound Blaster 2.0.
Did the S7 system have Windows 95 or 98 on it? If so, I guess they somehow got the card to work there.
Reply 4 of 12, by Almoststew1990
Thanks everyone I got it working with these 928 drivers. It sounds pretty good with it's YMF262F chip and unsurprisingly has SB16 support. I might get a Wavetable for it too. It also has a speaker out which I assume is unamplified so it isn't noisy.
Reply 5 of 12, by root42
Hm, there is a TDA1517 amp... so not sure about that "unamplified" part! 😁 Or are you talking about the line out?
YouTube and Bonus
Reply 6 of 12, by konc
Almoststew1990 wrote on 2022-07-01, 12:16:
Speaker out is always amplified, you are confusing it with line out I guess
Reply 7 of 12, by Almoststew1990
Whoops yes wrong way around!
Reply 9 of 12, by appiah4
Oetker wrote on 2022-07-01, 12:53:
Also there's no way it supports SB16, you mean SB Pro?
He probably picked SB16 in the game and the card is working in Mono without him realizing..
Reply 10 of 12, by Almoststew1990
Yeah it's mono 🙁
Reply 11 of 12, by appiah4
Almoststew1990 wrote on 2022-07-01, 13:42:
Yeah it's mono 🙁
Because your card is not SB16 compatible, just pick SB Pro instead.
Reply 12 of 12, by Joseph_Joestar
Yeah it's mono 🙁
OPTi cards don't have SB16 compatibility. They support SB, SBPro, and Microsoft Windows Sound System (WSS). To get the cleanest sound in later DOS games select WSS in a game's setup whenever that option is available. It sounds counterintuitive, but WSS works perfectly fine in DOS games which support it:
388.84 KiB
That said, you may need to set your card to WSS mode through the drivers before using it in that manner. I have an OPTi 82C930 which is a bit newer and the driver utility (SNDINIT.EXE) looks like this:
450.95 KiB
Since your card is older, the interface might be a bit different.
