First post, by voltorben
Hi.
I have used dosbox for a couple of years now, and this is the first problem I have ever met a problem.
When i launch dosbox, it just opens the status window and tells me that it's "loading primary settings from config file C:\DOSBox-0.70\DOSBox.conf", and then it crash!
I have used DOSBox on this same computer before and i worked all fine, but i have re-installed windows and now it doesn't.
System poperties
System:
Microsoft Windows XP
Home edition
service pack 2
Computer:
Intel(R) Pentium(R)III
Mobile CPU 933MHz
756 MHz, 256 MB of RAM
And im using DOSBox 0.70
I really hope someone can tell me what the hell is going on.
Thanks, Andy
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you are probably using different videocard drivers then before the reinstallation.
There are some threads going on about this issue. You have to set
SDL_VIDEODRIVER=windib before starting dosbox I recall
Water flows down the stream
Reply 2 of 3, by voltorben
theres is no "SDL_VIDEODRIVER" not even anything with SDL or VIDEO or DRIVER in my dsobox.conf...
Reply 3 of 3, by voltorben
no worries anymore. I found that using the CVS compile of dosbox works fine!
