Reply 20 of 31, by PC Hoarder Patrol
- l33t
Bancho wrote on 2021-08-12, 21:38:I have a EISA/VL system built, although its not really fully finished yet. I need to find the EISA Configuration utility. I have […]
I have a EISA/VL system built, although its not really fully finished yet. I need to find the EISA Configuration utility. I have the original disk but unfortunately its bad 🙁 I need to Change both Dallas's on it too as they are dead.
My board is a Asus VL/EISA-486SV1 which I currently have a DX2 66mhz and 16mb of ram in, CL VLB VGA Card and Tekram EISA HDD/FDD controller with 4mb cache
Did you try any of the ECU packages at this link, some of which contain your boards config file (!ASU4901.CFG)
