Reply 3840 of 4614, by Repo Man11
I decided to test the hardware by installing Windows 11. I knew it was too old for 11, but I'd heard there were work arounds, so I was killing three birds with one stone - seeing what I think of Windows 11, seeing how it goes when you install it on unsupported hardware, and seeing if this system actually worked. I did the registry edit when installing, and after that it installed with no further issues and Windows update works fine.
Reply 3841 of 4614, by weedeewee
My latest acquisition for which I am not easily finding info on the internet.
All the parts are in the box, the diskettes with drivers, one empty disc, the drive, the cables, all included.
Can still find some discs for sale on amazon, though they're in short supply.
oh, and while it says e-ide on the front of the box, it says it's parallel on the side, and since it's an external device and has a parallel cable included... it's probably both 😉
    75.5 KiB
    w27
Do not ask Why !
Reply 3842 of 4614, by Kahenraz
I wish magneto optical had become a thing. I imagine that it would have been a much more reliable and interesting evolution for removable media.
Even though we did eventually get flash media, it wasn't an affordable alternative for years and has never become as ubiquitous or disposable as floppy disks.
We did get writable CDs, but they are not a reliable form of storage due to the organic dyes, and aren't as useful or compatible as rewritable media. DVD-RAM is the exception, but it has always been expensive and never cheap and disposable.
Reply 3844 of 4614, by PC Hoarder Patrol
weedeewee wrote on 2022-07-11, 17:41:
My latest acquisition for which I am not easily finding info on the internet. All the parts are in the box, the diskettes with d […]
There is a Russian language page from 1997 which briefly mentions the release of the Verbatim OptiDriver 230 & 640 MO drives. Also (coincidence?) there was a company called Optisys who seemed to specialise in the optical storage market, including their OptiDriver device drivers, so maybe some kind of partnership going on with them and Mitsubishi (Verbatim)
https://web.archive.org/web/19980624194510/ht … m/opti2100.html
Reply 3845 of 4614, by weedeewee
PC Hoarder Patrol wrote on 2022-07-12, 14:07:
Nice find. It seems like they only did software..
I'll edit the post with some more photos later. at first glance it seems like it should be easy to open up the external drive... though it is definitely not just push & slide.
Do not ask Why !
Reply 3846 of 4614, by lolo799
There are plenty of Magneto Optical media on Yahoo Auctions if you're in need of discs.
Reply 3848 of 4614, by pentiumspeed
One or two were bad on a set of discs I bought came with the MO I think 800MB or so? 5.25" FH size drive. No longer have it anymore. The ones that worked needed dust cleaned off the platter surface, and drive needed recapped.
Cheers,
Great Northern aka Canada.
Reply 3849 of 4614, by Jasin Natael
Rescued two laptops from going to the scrapper, a Gateway Solo 2300 and a IBM Thinkpad 1171-1300.
The Thinkpad has a broken hinge and a subsequent broken lid, haven't done much with it. It has a Celeron 500 and a crappy passive matrix screen.
It also has a ESS Maestro sound card and a Silicon Motion 2D only card. Not sure if it is worth repairing at this point.
The Gateway also had a passive matrix screen but I have already replaced it with and active TFT panel and upgraded the ram from 16mb to 80mb.
This laptop seems fairly well suited to DOS gaming with a genuine Yamaha OPL sound card and less exciting but mostly suitable Neomagic 2d chip.
The laptop has a 166mmx Pentium currently, but I found a 266 Tillamook chip on ebay for 19 bucks, figured it was deserving of the upgrade.
If anyone has much interest in these upgrades I might post a follow up. Sorry no pictures ATM
Reply 3850 of 4614, by pentiumspeed
Solo 2300 has a fault that affected all: A screw backs out easily under the Pentium MMX module and short out. Best way is use low strength loctite.
My friend had 3 notebooks of these and all are affected.
Cheers,
Reply 3851 of 4614, by weedeewee
I've done it to myself. Now I truly have a memory problem.
only DDR2 and DDR in this photo. 2G 1G 512M 256M PC6400 <> PC2100
Do not ask Why !
Reply 3852 of 4614, by Jasin Natael
pentiumspeed wrote on 2022-07-14, 23:04:
Cheers,
Good to know, thanks for the tip!
Reply 3853 of 4614, by pentiumspeed
Oh, it has like 30 screws. And most unusual thing, the motherboard is also encased in metal tin box with more screws.
This what it looks like:
https://www.ebay.com/itm/255210677720
Cheers,
Reply 3854 of 4614, by BitWrangler
weedeewee wrote on 2022-07-15, 12:50:
I've done it to myself. Now I truly have a memory problem. […]
MoAr memory goooood. Though is that blue stuff real desktop RAM or smurf grade server stuff? ... I'm having to give myself a Rule or 3 or 4 though. No 30pin 1MB or smaller, no 72pin 4MB or smaller, no SDRAM 64MB or smaller, though exceptions made for 16 chip 32MB for VX and early 440 boards, no DDR 256MB or smaller, no DDRII 512mb or smaller, no DDR3 1MB or smaller and I think I'm gonna have to set the bar for 8GB and better for the DDR4, but barely got any yet. However, all the small stuff still sneaks in somehow, buy a box with large modules prominent and there's a bunch of shrimpy ones hiding under them. I ain't chucking them out or anything, just have a lifetime supply of the smaller stuff, which tends toward less useful than the bigger stuff.
Reply 3855 of 4614, by weedeewee
BitWrangler wrote on 2022-07-15, 16:13:
I know what you mean. I'll have to sort through it all and decide what to keep and what to part with.
Though for now...
Soundcards, videocards, networkcards, firewirecards, USB port cable, dimm, so-dimm, simm & some compaq armada laptop format modules, 1G doms and some Juzt-reboot thingamajigs.
not shows, a mac lc, a philips cdd 462, a commodore pc10-III and some keyboards, two of which I assume are XT.
Do not ask Why !
Reply 3856 of 4614, by Jasin Natael
pentiumspeed wrote on 2022-07-15, 15:48:
Oh, it has like 30 screws. And most unusual thing, the motherboard is also encased in metal tin box with more screws. […]
Cheers,
Seems about right. Most of these older small laptops weren't exactly the best thought out designs.
Reply 3857 of 4614, by Tetrium
weedeewee wrote on 2022-07-15, 16:57:
I know what you mean. I'll have to sort through it all and decide what to keep and what to part with. Though for now... […]
Though for now...
Don't forget to check if any of those SDRAM modules happen to by chance be VC-SDRAM 😜
Those remind me of the Reborn cards we used to have. I should even have a paper manual of one of those somewhere iirc?
Don't really have a good idea what I could use them for nowdays though.
My retro rigs (old topic)
Report spammers here!
Reply 3858 of 4614, by Horun
Wow ! Nice haul.
Reply 3859 of 4614, by holdencars11
Its local hard rubbish time...
Gigabyte GA-Z87 with i5 4670K
HUGE Phanteks Enthoo Primo Ultimate case... I looked up the PC CaseGear price in 2014 and it was $429AU!!
Other things..
WD Raptor HDDs
XFX 8800GTX
ADI Microscan CRT
Need to decide what to do with the case... maybe reverse sleeper or something..
    431.94 KiB
    615.74 KiB
    1.12 MiB
    616.3 KiB
    1.21 MiB
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
