First post, by Mouse0707
Hello
How can i Play RT on XP.
Freezes Computer when i click on Controls.
Thanks
Eiderdaus Was a Mouse
Hello
Thanks
Did you apply the Version 1.01 Patch?
Yes, bud this is not Playable on XP.
Cant configure the Controls. Computer allways Freeze.
Provided you have DirectX 8.1 installed properly, it should work.
I have no idea what the result might be under WinXP since it was intended for Vista and later, but you might try Felix Krull's Control Fix:
https://gitlab.com/fkrull/rallytrophy-control … -fix/-/releases
Thanks
I tried all,
Control 1,4 FIX, Game wont start.
Microsoft Direct Input Mapper, wont Install.
Hello
Sorry for Double,
Play RT bud with incorrect Gamepad Configuration, Steering:
Analogue Stick Forward is left
Backwards in right.
You should Play it with the Same, so is RT very Hard to beat. It take a lot of Time to Finish this. Bud with correct Configuration, RT is for me to Easy.
I Forget about, when i First Start the Gamepad Configuration, it worked.
Bud only once, never second.
My Hardware Stands in the GP 500 Thread.
Worldwide the only good Gamepads
RT have Performance Problems, in Kenia.
Test it on Pentium E5400, 8800GT, XP 32Bit
Test it on 6000+, 6670, XP 32.
Controls Freeze.
Delete RT
