First post, by gamingretro
gamingretro
Offline
Hi folks, I'm hoping someone has got an easy solution for this. I am trying to run lords of the realm ii on Windows 98 SE. No matter what I do it simply will not detect the CD, so upon loading the game says I need insert the CD to play (even though it's in the drive). I've used the following workaround for WinXP but it didn't seem to work for 98: https://gamefaqs.gamespot.com/pc/197801-lords … here-is-no-disc
Any ideas? Thanks!
