Looking for a compact DOS machine
First post, by t_r
Hello all,
I am trying to find a compact all-in one solution for DOS gaming (no dangling external USB converters etc.). I stumbled upon something called WeeCee which would fit my requirements perfectly but it seems it's just a hobby project and not commercially available. I am thinking maybe I can build something similar myself, but first I just wanted to check if there are any other options. I have seen small form-factor business PCs on Ebay but they always seem to lack some features such as underclocking the CPU.
As for authentic DOS experience I'd like MT-32 emulation or equivalent, I have not yet decided how to implement it, do PCI soundcards generally have this feature in DOS? For display I was thinking 1920 x 1200 flat screen since it should support 320 x 200 rescaled to correct aspect ratio and CRTs kinda defeats the compactness requirement.
Any tips regarding to this kind of build are greatly appreciated, thanks.
Reply 1 of 21, by Joakim
I guess there are ATX motherboards with highly compatible built in video cards, but you probably need a separate sound card for dos fm sound. Some PCI sound cards can work in dos even without sb link. Maybe you can get some kind of riser board and make it smallish.
The cheapest option is probably to buy a laptop maybe from 1998ish. You can even rebuild a broken one and fit it into an LCD screen I guess.
For graphics chips I think you generally should go S3 or Nvidia.
Reply 2 of 21, by t_r
Joakim wrote on 2022-07-20, 18:08:
ATX
ATX is too bulky for me at this point. I'm after something like this: https://www.youtube.com/watch?v=2P1E2vjpcRo maxresdefault.jpg
Sadly it's not easy to find such a compact solution. The best options I have found is building something similar by myself or getting these nettop or whatever they are called proprietary PCs.
Reply 3 of 21, by jheronimus
t_r wrote on 2022-07-20, 17:50:
Just my 2 cents: if you're talking about MT-32 emulation by soundcards (as opposed to, say, running Munt, i.e., software MT-32 emulation), then yeah, there are a few soundcards that emulate MT-32 — for instance, Ensoniq AudioPCI. But you have to keep in mind that those cards only remap existing MIDI samples that don't sound like MT-32. Also, they don't support intelligent-mode MPU (games, that load their own samples into MT-32). There are a lot of games that do that. So Monkey Island 1 will work, but will sound different. MI2 won't.
MR BIOS catalog
Unicore catalog
Reply 4 of 21, by t_r
jheronimus wrote on 2022-07-20, 18:30:
Honestly I have not yet decided whether I should add something like Raspberry Pi based emulation, or if something provided by the soundcard itself would be adequate. If Munt runs on DOS it could be a solution as well. Anyway thanks for your 2 cents, I need every kind of advice now as this will be my first DOS PC on modern(ish) hardware.
Reply 5 of 21, by oso2k
t_r wrote on 2022-07-20, 18:34:
Maybe emulate it on a Pi4B or an old Dell Optiplex/HP Prodesk/etc. running Lakka or RetroArch? On ebay search for "USFF"
https://youtu.be/LRy8brZ7DVc
https://youtu.be/gKAO13LBnkc
https://www.ebay.com/itm/195101210235
https://www.ebay.com/itm/195101473896
Reply 6 of 21, by BitWrangler
Phil did a piece on a Wyse thin client (be wary, a lot of Wyse hardware dumping at the moment seems not to be x86) then there was also a project to get DOS running on the MCU in a KVM box, but I guess sound wouldn't have been included.
The actually useable version of dosbox to try for free on a tablet, android TV box or phone from google play is iDosBox
Reply 7 of 21, by leileilol
if you're looking for vintage small OEM desktops, there's Compaq P3 SFFs from early 1999 that have an onboard Rage Pro and ESS (good enough for most DOS games). Unfortunately they're too constrained to drop a 3dfx V1/V2 in.
Reply 8 of 21, by BitWrangler
There's P3 deskpros that aren't all that large in physical dimensions but weigh a ton still, that you can probably get V3 and soundcard into.
Reply 9 of 21, by oso2k
BitWrangler wrote on 2022-07-21, 01:19:
See https://www.parkytowers.me.uk/thin/hware/hardware.shtml for other thin clients.
I'd avoid Wyse. I have 3x Wyse S10, 4x Wyse Vx0, and 4x HP T5745 with the expander module.
The S10 beautifully small, will run DOS nicely at a good clip (like a fast PII), VGA is more compatible with DOOM & Quake but audio is not and needs to be addressed, as does booting and installing DOS since it only likes to boot from DOS HDD images, no ISO burned to USB, or FDD burned to USB booting.
My Vx0 are broken and don't seem to like the RAM and will enter a boot-beep loop if I try to change a BIOS setting. Wiping the BIOS CMOS is the only to get it temporarily rebooting.
The HP T5745 are super fast (like fast P4), have dual threaded Atoms, do a ton of RAM (8GB!...for DOS that is a lot), BIOS will mount any FAT16 or FAT32 formatted drive as a semi compatible HDD on any of the 8x USB2.0 ports or the internal SATA port, have super fast but somewhat DOS incompatible VGA chips, and a DOS incompatible sound chip that necessitates the expander module. The most PC-like BIOS of the bunch.
Reply 10 of 21, by RandomStranger
There are AMD K6 based thin clients with expansion card options, though they are very rare. If you get one and add something like an ESS Solo-1, that's probably the smallest you can get without sacrificing too much compatibility.
https://www.dosforum.de/viewtopic.php?t=11406
Reply 11 of 21, by Jo22
+1
DOSBox Turbo (Free) workes for me on an Android TV (the least "SD card" mounting issues).
On my tablet, IDOSBox works fine, too.
That's really funny, if I (we) think about it. What essentially is part of a modern day monitor, can run our vintage all of its own.
No need to attach something like a 286/386 PC, unless we special hardware is needed.
An old DVD/Blu Ray player thus becomes a fully usable Android "PC" we can run specialized software on.
Like a satellite tracker, an SDR receiver application, an AF function generator etc.
Feels a like working with tech of a post-apocalyptic world, IMHO.:
Image people wandering through the ruins of cities, looking for old consumer's electronics (appliances) which they repurpose as computers.
And the irony is, that actually works. It's possible to run an 3,5" USB floppy drive/optical drive on a SmartTV. So someone can retrieve JPEGs stored on diskette taken with a Sony Mavica camera, originally .
    239.13 KiB
    100.23 KiB
    110.38 KiB
    156.64 KiB
    118.61 KiB
Reply 13 of 21, by t_r
RandomStranger wrote on 2022-07-21, 05:45:
Looks really nice. Today I have been doing research on thin clients, but most don't have DOS compatible sound cards, and if they have PCI expansion slot I have been told only ISA cards are fully supported on DOS, although I am not sure if this is completelly true.
Reply 14 of 21, by t_r
Joakim wrote on 2022-07-21, 16:46:
Watch out! The emulation people wants to eat your brain!
I won't give in, I already have a powerful desktop PC which can run DosBox fine, but I want the real thing (if one can call DOS on modern hardware that). Besides if I wanted emulation I'd go for MiSTer with ao486 core.
Reply 15 of 21, by Jo22
Truely native (fully hard-wired) hardware rarely exists anymore, I suppose. Emulation/programmable logic is everywhere. Even at the ISA level. 😁
https://en.wikipedia.org/wiki/Microcode
https://en.wikipedia.org/wiki/Intel_Microcode
https://forum.vcfed.org/index.php?threads/808 … assembly.77933/
https://en.wikipedia.org/wiki/Transmeta_Crusoe
Reply 16 of 21, by t_r
Jo22 wrote on 2022-07-21, 19:43:
And if you interpret some laws of physics in a certain way, even the reality itself seems to be running on some sort of "virtual machine"...
Forgot to comment previously but a nice photo of Gateway btw, that game is great!
Reply 17 of 21, by BitWrangler
Yeah, you shoulda seen the frantic GPU upgrades the masters of the universe had to do to be ready for James Webb Space Telescope turning on.
Reply 18 of 21, by henk717
Give the T5710 a look, they can be bought cheap. Got ATI Radeon 7000 graphics and with an unofficial utility you can get soundblaster support under DOS.
On top of that you can add some soundcards using PCI if you need one.
Reply 19 of 21, by DOSDays
Many years ago I bought one of those tiny PC systems that @t_r posted a YT video of, with the purpose of having a very portable DOS gaming box when I travelled.
Everything was great apart from the sound card support. As I recall it had a rather obscure audio chip, like a CMedia one, that was Sound Blaster/SB Pro/SB16 compatible in Windows, but absolutely not in DOS due to it running on the embedded PCI bus.
My understanding of intelligent mode MPU is that it has nothing to do with whether games load custom samples into the MT-32. It's more to do with how the handshaking occurs with the external MIDI device, and whether the game waits for an 'ACK' (acknowledge) response from the device before it recognises whether it's an MT-32 or not. I'm sure a number of games that work perfectly in UART mode load their own custom samples but I'm happy to be corrected.
