First post, by assortedkingdede
I installed drivers for a Nvidia GeForce 200 MX GPU however the computer acts wonky. It can use True Color mode but the screen savers cause illegal operations and DirectX does not detect a 3D accelerator but does see the card. I am using the 81.98 driver version for Nvidia. The computer can run Sonic 3 and Fallout 1 fine, I have not bothered with any 3D games until I fix this issue. Any information would help. Thanks!
Reply 1 of 3, by assortedkingdede
assortedkingdede wrote on 2022-07-22, 15:40:
Update: tried Quake II, game ran at lowest resolution and the sound was beyond awful.
Reply 2 of 3, by Joseph_Joestar
Those drivers are too new for the card that you're using.
Uninstall the existing Nvidia drivers via Control Panel > Add/Remove Programs then install 12.41 drivers. This is the Win9x version, which I'm assuming is the OS that you're running.
My retro stuff
Reply 3 of 3, by assortedkingdede
Joseph_Joestar wrote on 2022-07-22, 17:49:
Just did this, everything looks fine, thanks for the help.
