First post, by Alistar1776
It seems my DOS copy of DOOM wont install on windows 98 in dos mode, but has no problem installing to something solely on DOS 6.22. I assume this is an issue with DOS versions and compatibility, unless theres something else im missing. The error i get is "Sector not found reading drive A. Abort, Retry, Fail?" or if I manage to get to the installer, and begins copying files, it says "Big problems reading this disk!" Thanks for the help.
