First post, by dr.zeissler
Hi, can we collect better textures or hires textures as upgrade for the original game-engine, so it could be played on the same machine as it came out.
Reply 1 of 11, by leileilol
The only fitting example (hi-res + original engine + old machine) I can think of are S3TC texture packs for UnrealEngine1 games for MetalDrv and donhal's D3D/GL renderers. Anything else gets into modern source ports / modern API wrapper hijack territory.
"Better" is also quite subjective too...
Dp9fHL2UwAAUYDL?format=jpg&name=small
Debian's fucked
Reply 2 of 11, by dr.zeissler
Gunman Chronicle HD Pack.
This is it, I use some from existing pack of other authors and carefully add them, you don't need Xash3d to play.
Enable "r_detailtextures 1" in console. All missions in-game and default multiplayer maps are included.
Also, I recommend using Half Life HD pack to cover some missing HD textures.
https://gamebanana.com/mods/download/355598#FileInfo_742314
Reply 3 of 11, by matze79
leileilol wrote on 2022-07-24, 19:12:
The only fitting example (hi-res + original engine + old machine) I can think of are S3TC texture packs for UnrealEngine1 games […]
Original still looks best to me.
Gunman Chronicles was great I liked this game.
Reply 4 of 11, by Peter.Mengel
Hahahahahahahahahahahaha !!!!
Wow that pic made me rly lough hard!
Thanks for it.
Reply 5 of 11, by The Serpent Rider
Resident Evil 4 retexture project is one of the most famous.
Reply 6 of 11, by dr.zeissler
RE4 is DX9 P4 WIN2K, I should have been more spefic to win9x games from around 1998-2003 that will run on a P3-Tualatin. (I am checking different PCI gfx-cards on this).
Reply 7 of 11, by dr.zeissler
UNREAL1 with S3TC Textures on the second UT99 cd work with the correct e.g. upgraded OGL Driver and a S3TC capable card (like GF MX4000 PCI/64MB)
Reply 8 of 11, by dr.zeissler
Now I am checking for "Blood2", "Severance", "Quake1+2" , for Q3 I only use "Kai's texturefix" in my opinion very good and with 96MB very light.
Reply 9 of 11, by dr.zeissler
Halflife1 can be updated with blue-shift, I have to check that. I did not get gunman HD-Textures to work...I think placing that line in config.cfg is the wrong way.
Reply 10 of 11, by dr.zeissler
what is the best texture pack for the original halflife1 (no steam, no Xash3d) , I already installed HL1 updated to 1110 and installed opposing force and blueshift with high definition pack. I only need some better textures. thx!
Reply 11 of 11, by leileilol
There is no support for external texture replacements.
Debian's fucked
