First post, by Kahenraz
DOS executables without an accompanying .PIF file will run in a dosbox with a set of default options. Is there a way to modify what these defaults are for all programs?
Reply 1 of 4, by weedeewee
my memory is a bit vague... wasn't there a default .pif or shortcut in the windows directory for that purpose ?
Do not ask Why !
Reply 2 of 4, by Jo22
I think the same. I do remember it from Windows 3.10.
Windows 3.x also had a PIF Editor..
Reply 3 of 4, by Kahenraz
I tried modifying all of the .PIF files in the Windows directory without any luck.
Reply 4 of 4, by hail-to-the-ryzen
Can see if some of the options are in the registry, possibly here:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Current Version\MS-DOSOptions
