First post, by UltimateElectronic
The ViRGE card has an 86C375 chip on it, the Trio has an 86C775 chip on it.
The system it's going in has the following specs:
430TX QDI Titanium IB+
Pentium MMX 200
64MB PC100 SDRAM
SB AWE64
Windows 95
Reply 1 of 5, by Datadrainer
Which is better? ... in what field? Better in the void mean nothing. What do you want to do with it?
For what I know about this chips, they are both based on the same design, both are good for 2D (DOS & Windows) and both are pitiful for 3D but the ViRGE was sold for it (Edit: meaning it has S3D and Direct3D enabled in the driver).
Except for that, there is surely some difference here and there. But I think the 86C775 is most likely a revision of the 86C375. Of course, I can be wrong and someone with more knowledge will tell us that.
I suppose you are not interested in early 3D games, but with a 3dfx Voodoo your build can be even greater 😉
Knowing things is great. Understanding things is better. Creating things is even better.
Reply 2 of 5, by The Serpent Rider
Trio 64V2/DX has better RAMDAC. Performance won't be significantly different between them.
Reply 3 of 5, by 386SX
Wasn't the Virge/DX the 375 revision number and not 325? Anyway if I'm correct the Virge/DX should be more complex (for what it matter) as a gaming oriented early 3D (and good 2D) accelerator while the Trio64V2/DX was still a good 2D only accelerator, same RAMDAC clock but from specs that should be better in the Trio64V2 (while I suppose the output quality will depend as usual by the manufacturing quality of the whole card/brand). Edit: I thought the Virge/DX also had some MPEG1 acceleration but not.
Reply 4 of 5, by The Serpent Rider
Didn't noticed Virge DX in the title. Oh well, yes, they have identical RAMDAC, but in ideal scenario Trio 64V2/DX is slightly faster anyway: PCI Video cards benchmark: Electric Boogaloo Edition
Compared cards in the flesh: Re: Graphic card memory speeds
Keep in mind that any improvements on PMMX200 will be from minuscule to none. And built quality and clocks between different brands varied noticeably.
Reply 5 of 5, by Revolter
I'd say the main advantage of S3 ViRGE/DX over its 2D-only counterpart is the hardware support for API (S3D)-exclusive games - such as Terminal Velocity <3 Also Destruction Derby, FX Fighter Turbo, Havoc and Screamer.
After some overclocking anyway.
Celeron 800@1066, 512MB, GeForce2 MX AGP/GeForce 8400GS PCI, ES1938S/Dreamblaster S2, DOS 6.22/Windows 3.11/Windows ME/Windows 2000
