The K6-2 "RATS" PC
First post, by drosse1meyer
Greetz All!
Here's my latest acquisition / renovation / build.
Stock specs were AMD K6-2 @ 300 mhz, M571 motherboard, 64 mb SDRAM. The AT style case has most of its hardware intact as well as the bracket+headers for the onboard motherboard features. It is in excellent condition and both CDROMs work fine. I like the bezel which holds the LEDs. There were no other cards installed in the system (onboard sound/VGA).
Even though it was described as 'working' a few fixes were needed to get it up and running, mainly disabling the motherboard cache and fixing a short. The master/slave settings were a mess for some reason too.
The motherboard supports both SDRAM and EDO, as well as AT and ATX style power connectors. The integrated sound, CMI 8330, can work in a variety of configurations but in my limited testing seems best as SB 16 (both DOS and Win98)
I'm not sure if I should keep the stickers, I kind of like them 🤣.
Modifications:
Added Nvidia MX200 and disabled onboard VGA
Overclocked FSB to 83 MHz
IDE-SD card for mass storage
To-Do:
More RAM?
Experiment with other CPUs?
Fix cache somehow?
Open to comments / ideas/ suggestions.... Thanks for checking it out!
Reply 1 of 7, by Repo Man11
I'd dearly love to get a deal on an AT case such as that one.
Since these boards support the K6-2/3+ I would be unable to resist upgrading it to one of those, especially in this case since the onboard cache isn't working.
Reply 2 of 7, by drosse1meyer
Repo Man11 wrote on 2022-08-01, 00:29:
Yeah these cases are definitely becoming more rare with each passing day
I agree, the 3+ would be a nice addition!
Reply 3 of 7, by Errius
Those little cases have poor ventilation though, especially if you put a hot video card like a Voodoo2 in.
Is this too much voodoo?
Reply 5 of 7, by drosse1meyer
Errius wrote on 2022-08-01, 02:45:
Yeah there's space for a fan and ventilation holes in the front but the front cover blocks most of that. I put a fan on the MX200 which is doing the trick.
Sphere478 wrote on 2022-08-01, 06:47:
Definitely need a 3 or 3+ with that disabled cash
Buy a 2+ 570 and mod it
Could be an option, but I can't seem to find many 570 on ebay? There are 500AFX for cheap but reading your post it appears those have a much lower chance of success.
Reply 6 of 7, by Sphere478
https://www.ebay.com/itm/274825467551?hash=it … -8AAOSwvYNgvk3V
https://www.ebay.com/itm/165591645766?hash=it … VwAAOSwI8ximYNv
Sphere's PCB projects.
Reply 7 of 7, by drosse1meyer
Sphere478 wrote on 2022-08-01, 19:56:
Oh wow, thanks! Idk why that didnt come up in my search
