Reply 22300 of 30428, by BitWrangler
Was that based on DR-DOS by 5.02? I used to have some DR-DOS disks that I used for aligning drives with, because they would read when they were just out of adjustment enough to stop reading everything else. So if it read nothing, I'd eyeball it until it read the DR-DOS disk, or start from where it was still reading it, go all the way one way, until it gave corrupted dirs, then all the way the other way, until same thing started happening, then center it between the two, and everything would read fine again... once or twice I had to do some real fine tuning.
Reply 22301 of 30428, by Thermalwrong
I've gotta make a write up on this at some point. I keep getting stuck into one project after another and I'm slowly working through them - the most frustrating lately has been a Toshiba Portege 3010CT laptop that I dropped off a tall shelf. The laptop was fine but the CCFL in the LCD was smashed. CCFLs are expensive so I opted to put an LED backlight in instead but it turned out to be a big can of worms.
To start with, this is a super thin laptop so it barely fit and the LED backlight needs 12v where the laptop gives 5. So I reverse engineered a small 5v > 12v boost converter and put it onto the protoboard I was gonna use for mounting:
The attachment Toshiba-Portege3010CT-Inverter-6.jpg is no longer available
The attachment Toshiba-Portege3010CT-Inverter-3.jpg is no longer available
This actually lead to KiCAD to figure out how it fit together to re-make it. That mess of wire works.
Then I found that the dimming method Toshiba use for these old laptops uses some pins for a binary counter i.e. 00, 01 etc. The new LED backlight uses an analogue voltage for brightness, so 5v = dimmest and 2v = brightest. Apparently that's the more common / later standard.
This lead me on to using an Arduino / Attiny2313 I had laying around to do the reading and have it make a PWM signal - I haven't done anything with arduino in a few years so there was a lot to pick back up 😀
The attachment Toshiba-Portege3010CT-Inverter-5.jpg is no longer available
It's a really cheap backlight board which apparently isn't the best - it flickers at low brightness so when the hard drive was busy, it would flicker. Solved that with an RC filter on the PWM signal so now it doesn't really flicker. The brightness controls actually work, ranging from "this is a bit dim" to "agh my eyes"
The attachment Toshiba-Portege3010CT-Inverter-1.jpg is no longer available
The attachment Toshiba-Portege3010CT-Inverter-2.jpg is no longer available
There's still a couple of tweaks to make, which will involve pulling it apart again and reflashing the attiny in circuit again, but overall this has been a nice project. It's really rejuvenated the look of this laptop compared to its original CCFL.
Reply 22302 of 30428, by MarkP
BitWrangler wrote on 2022-07-29, 01:06:
The initial release of MS/PC Dos 5.0 was a bit flakey. Both MS and IBM put out new versions that fixed that named 5a and 5.02 respectively.
MS/PC Dos 5.x/6.x fdisk would not sort out the partition table on a Conner drive I have but DR Dos 6s fdisk got it sorted in no time. So pays to have them handy. On one hdd I had a version of Linux sort out a partition as well. 5 hdds out of 6 all good to go 😉
Reply 22303 of 30428, by 386SX
Today I'm choosing old components for a new main machine on linux. I installed again the Athlon II X2 2,7Ghz on AM3 Nvidia chipset, 4GB DDR2 800, HD4650 1GB, SSD SATA2 and I went for a alternative old sound card to see how it would run on a modern light linux o.s. and it works great, the Sound Blaster PCI (Ensoniq ES1371) and it's more powerful than the on board and it just work great. It's a sort of mixed components machine, even an IDE DVD drive.. 😉
I was thinking to even use some older still supported video card like the X550 series or something like it maybe less complex for an office machine. Obviously I need at least OpenGL 2.0 as generic apps requirement.
Works great.. too bad for the lack of the SSE4.1 as lately talked about but still working good. I might look for a cheap Phenom II but this one seems to be less power demanding. In idle the system ask for 45 watts more or less with automatic clocks.
Reply 22304 of 30428, by BitWrangler
I'm cooking up something similar as a "final" upgrade to an AM2+ box (Isn't yours that too with DDR2 ??) Some nforce 6100PM-AM board, and I'm chasing a cheap Athlon II x4 locally. Supposed to be some workarounds to get SSE 4.1 out of the SSE 4.0a that I'll look into. I had mine on a power meter with Phenom X3 and GT610 in it and it was idling at 25W. I don't even think that was the 8450e I've got, just the straight 8450. Build up might appear in modern thread eventually. Only got 2 RAM slots to play with too, but have one piece of "AMD only" 4GB DDR2, which I'll give a shot, so may be running 6GB until I find another one.
Reply 22305 of 30428, by appiah4
BitWrangler wrote on 2022-07-29, 13:38:
Curious as to what you will use this box for? I really find it hard to justify building anything post Socket A; I have a Socket 754 system and that I only keep as it is the fastest AGP platform I have, otherwise it's pretty useless..
Reply 22306 of 30428, by BitWrangler
It's more gonna be a low end modern donkey than retro gamer, hence why I'll detail it in modern when it's getting seen to. It might get some media handling duties and emulators. What I'd call "emergent retro" targetted at late noughties will be a s939 x2 with crossfire 4870s, and a s775 sparring partner with SLI 9600s. I've got a 754 for AGP final fling also, but so far best it's getting is Radeon 9600, waiting for something better to turn up for peanuts.
edit: You know what, though, maybe I'll be using the 4870s for peak 1st gen AM2, got an X2-6400 and board. Better era and CPU grunt match. Think I might have pair of 7000 series nVidia for the 939 that are more 2006.
Reply 22307 of 30428, by appiah4
BitWrangler wrote on 2022-07-29, 14:04:
Yeah I was going to say 4800 series is more an AM2 thing and you should probably go with a 5850/6850/7770 with that AM3 build..
Reply 22308 of 30428, by BitWrangler
Might get the HD7750, will know when the music stops 🤣 Though it does seem like I'm gonna have a bunch of 68x0 unemployed... I'd keep the 5850s as there were more top of line where the 68x0 was overshadowed by 69x0... and are just more of the same terascale.. dang I shoulda got $100+ a pop for them peak GPU drought last year.
Reply 22309 of 30428, by 386SX
Interesting, my mainboard has a MCP61 chipset which iGPU I can't use anymore in linux cause proprietary drivers are too old. Dual DDR2 dimm for 4GB 800Mhz at best, SATA II, IDE, AM3+ support and 2010 latest bios. About the SSE4.1 as discussed lately I found that they were a very long list of newer instructions compared to the four ones of the SSE4a AMD one. I can't imagine how they can workaround the SSE4.1 but very interesting if there were some way to at least keep the newer compatibility requirement if needed.
Also 25 watts with a Phenom X3 and a GT610 looks impressive even in idle. I imagine it was an ultra high end PSU to have such efficiency. 😉
Reply 22310 of 30428, by BitWrangler
Yes I was very surprised, checked it with a moving coil ammeter clamp too and it was flickering around 1/4 amp on that, though scale wasn't the best for it. So coulda been 5 watts higher. That was sitting on desktop with no disk access though, dunno what power state it was actually in. Was on windows 7 I think with all the eyecandy turned off. As soon as it hit the disk it jumped 10W. Just leave it noodling background stuff like file copying or something and it was 40. The 610 runs really low when not doing much. I can't remember PSU at the moment, might have been an older ATX 2 enermax. Might have been a "this one feels heavy enough not to be total crap" OEM. I think though that from mid noughties HP, Dell, IBM were putting actual effort into having even their low end biz PCs be efficient, like they maybe had 90% designs before all that white bronze silver gold platinum etc deal. I think actually it used to unnerve me by turning the fan off completely until it got a little loaded.
The workaround I was thinking of was the intel SDE for devs, in the 7.x.x versions, that emulated SSE 4.1 ... it was really only much use in very CPU light games and games for which you needed to confirm whether SSE 4.1 was an issue. The rest was all individual patches and workarounds for popular games. Might have oversold how useful that is.
Reply 22311 of 30428, by lolo799
Gave Virtual Waves 2 a try under Win95 with a SB32PNP or an Awe64Gold and no dice, the included Sample Transfer doesn't recognize either of my cards.
The attachment vw2error.png is no longer available
It's the 32bit version of the program but it relies on two 16bit dll dating back from 1994, aweman and awegui.
The attachment vw2dir.png is no longer available
For illustration purposes, the Virtual Waves AWE32/64 Transfer and awegui dialog windows
The attachment vw2awe.png is no longer available
The attachment awegui.png is no longer available
Has anyone ever managed to make it work, I wonder...
Reply 22312 of 30428, by creepingnet
The Tandy 1000A is now 100% on the internet - DOSLynx is installed and working (with the Deluxe Mouse on Joystick Port #2 no less), FTPSRV has been working overtime, most of the RAM issues are sorted. I'll say this, that mTCP upgrade REALLY freed up some KBs, the old version I had was around 468K at boot, now I have 490K with networking. Also did some tweaking (added DOS to UMB - whatever's not used by CGA and the other Tandy/Option ROM Stuff).
Seems I'm gaining some more speed now as well, kind of odd being as it's a 4.77MHz 8088. Only games not working now are Ultima V and Ultima VI (well, intro works on VI). Just a little more Memory tuning and I think we have the Tandy up to speed with the others (minus the hot-rodded hardware upgrades I have planned).
~The Creeping Network~
Reply 22313 of 30428, by BetaC
After a few weeks of frustration, I suddenly have a working light sixer.
The attachment IMG_0183.jpg is no longer available
It's time for me to now play some not-that-great-at-best games on this classic.
The attachment IMG_0186.jpg is no longer available
Reply 22314 of 30428, by HangarAte2nds!
Took a look at my retro games to see what I want to play in the near future and decided I need to build a PIII. Have 4 MBs all slot 1 and upwards of 10 CPUs some Slot 1 and some PGA, from 400MHz to 1400MHz. I have an adapter for the PGA ones. Have plenty of components to finish it out, taking my pick. Plenty of AGP GPUs, drives and RAM. Everything is untested so I will just sort of be winging it and part of the project is to start testing components I have spent a couple of years collecting. I have several CRT monitors that are status unknown. The ones I most want to play are from 2000-2002 so I probably won't try to go balls to the wall with the first build. I will probably end up with more working PIII builds than I need. Thinking about trying to sell one but not sure if I will have much luck finding a buyer. It will be in a very heavy full tower and not something I can ship and there is not much going on in the PC section of my local CL. But I should have some fun in any case.
Reply 22315 of 30428, by PTherapist
My retro related activity today (well, yesterday really) - repairing/bodging some PC speakers that I've had for about 19 or 20 years, though they're being used on my main modern day system as they still sound damn good!
I have the Cambridge Soundworks Desktop Theater 5.1 DTT2200 speaker set and for years I've been putting up with the failing potentiometer issue, whereby the volume levels will fluctuate at random, high & low. The issue would go away for ages and only reappear from time to time. The recent heatwave we had seemed to have brought the issue back in full force and I'd finally had enough and in frustration ended up damaging the potentiometer.
The thing is soldered down and welded together, so no easy job of a clean & repair and it would only be temporary anyway, plus you can't seem to find exact replacements for these particular potentiometers anymore. So I decided to just bodge it - found the schematic online, chopped off the volume control and shorted the relevant wires together to achieve power on + full volume. It's working well, can just use Windows to control the volume levels for now.
I've bought another set of Cambridge Soundworks speakers, but the lower model 4.0 surround version. The volume control, whilst looking different, seems to use the exact same connector, so I might be able to just use that instead and keep the 4.0 set as spares. But further down the line I intend to purchase a different potentiometer and attempt to build a replacement volume control to fix the temporary bodge job, albeit sacrificing the left/right balance control - which I never used anyway.
Reply 22316 of 30428, by creepingnet
Well..I finally put a HDD LED in the Tandy yesterday, I got sick of not being able to see when the system hangs.
Had a weird bug yesterday, just left it after some gaming and the screen started getting random ASCII characters randomly placed about the screen. STrange since the RAM is fine, so I reseated it anyway, one of those "while your in there" things.
Got to mess around on FTP last night - this time as a client - got the hang of it in 5min, not sure what I was so scared of using a DOS a FTP Client all this time, heck of a lot easier than a GUI.
Installed Paku Paku and Hoyle Book of Games volume 1 on the Tandy this morning. Have not cracked them open, maybe I should tonight since I'm about to go all Norman Bates level crazy after doing some accounting (I HATE accounting....but it's a necessary evil).
Still holding off on the #SEPTandy Hardware project for YouTube.......waiting till I have more funds. The damn screen for the Versa (M/100 loose screen) sold so I'll have to go with the $45.00 option to fix the P/75 later down the road. Meanwhile, still whacking away at that Retro Lawn Mower to get the blade adapter off so I can replace the oil pan that has bolts stuck in it.
Reply 22317 of 30428, by NyLan
Fixed "some" pins on a 486 Dx4-100 I just bought
The attachment 2022-08-03 14.31.34.jpg is no longer available
The attachment 2022-08-03 13.53.22.jpg is no longer available
The attachment 2022-08-03 13.53.29.jpg is no longer available
The attachment 2022-08-03 14.28.30.jpg is no longer available
The attachment 2022-08-03 14.29.02.jpg is no longer available
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 22318 of 30428, by TheMLGladiator
How did you straighten the pins out so well?
Reply 22319 of 30428, by chrismeyer6
NyLan wrote on 2022-08-03, 12:36:
Fixed "some" pins on a 486 Dx4-100 I just bought […]
Oh man that poor cpu. Your straightening job looks perfect what's your secret?
