First post, by Sphere478
I have a gateway 2000 with pentium overdrive 83 and 32 mb of ram
What’s the fastest video card I can get for it? 😀
I’m wanting to max out all the system specs. 32 mb seems to be the max. I could put a faster mhz processor in it with a interposer but I’m thinking the POD might be a good bet as is though? I have a amd 586 133? But would need to get a interposer (no biggie, I made one 🤣) Re: Socket 3 Tweaker
Anyway, the graphics card, I have no idea what to look for. I saw a few benchmark comparisons and searched some of the top performers but they are 300$ on ebay which is nuts 🤣.
Any practical suggestions or am I gonna be stuck paying that much if I want a record performer?
Sphere's PCB projects.
Reply 1 of 21, by rmay635703
The best ISA Video card for a 486 is a VLB or PCI card
Reply 2 of 21, by Sphere478
rmay635703 wrote on 2022-08-09, 00:18:
I’ve no doubt but this system doesn’t have those busses 🙁
Reply 3 of 21, by rmay635703
Sphere478 wrote on 2022-08-09, 00:19:
What’s the onboard chip?
It wasn’t unheard of for the onboard video and ide to be a local bus.
Sometimes an ISA card outruns vlb but it depends on the chip.
Reply 4 of 21, by BinaryDemon
If you don’t have PCI or VLB then your best bet is sticking with the onboard Cirrus Logic CL-GD5428. I’d bet it’s on a local bus which will make it faster than anything ISA.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 5 of 21, by Sphere478
I’m having problems with it. It is crashing when I try to open cpuz that’s as far as I have gotten
I have some more video ram I can put in it. Would that be why it it is crashing though? Seems unlikely?
Reply 6 of 21, by BinaryDemon
Is cpu-z the only time it crashes? I’d run a whole bunch of other tests first. Maybe you just hit a rare incompatibility or there’s another issue.
Reply 7 of 21, by Sphere478
BinaryDemon wrote on 2022-08-09, 00:37:
I haven’t really got it running yet. I booted ME on it from my xt-ide in a attempt to copy files to the scsi to start a win 95 install but haven’t had more time to mess with it. But it is glitching out when I launch cpu z it shows graphics glitches and freezes.
Reply 8 of 21, by maxtherabbit
BinaryDemon wrote on 2022-08-09, 00:24:
this
Reply 9 of 21, by maxtherabbit
Sphere478 wrote on 2022-08-09, 01:27:
my dual coppermine hard locks when running cpu-z
works 100% perfect otherwise
Reply 10 of 21, by red-ray
maxtherabbit wrote on 2022-08-09, 03:33:
If you edit CPUZ.ini and change all the xxx=1 to xxx=0 does CPUZ then start OK, if so then restore each to =1 'till you find the one that triggers the lockup.
Is it just CPUZ that causes lockups? Does my SIV utility? If SIV also has issues from a command window do SIV32L -DBGINI and post the generated SIV_DBGOUT.log to my SIV thread.
Reply 11 of 21, by CuPid
Sphere478 wrote on 2022-08-09, 00:29:
hello Sphere 478,
You use cpuz vintage edition, right ?
can you please edit cpuz.ini and set :
Sensor=0
and try again ?
Thanks
I need a vacation.
Reply 12 of 21, by CuPid
hello maxtherabbit,
as suggested to Sphere478, can you please try with Sensor=0 in cpuz.ini ?
thanks !
I need a vacation.
Reply 13 of 21, by Sphere478
I am using vintage edition. For 9x
But I won’t be able to try these out for a while. Will have to get to it when I am back in front of it
Reply 14 of 21, by Tiido
Looking at the mobo, there are bus buffers at the Cirrus and this strongly suggests it is VLB connected so as said previously, it will be far better than anything ISA for that machine.
Reply 16 of 21, by Sphere478
Out of curiosity what is the maximum supported amount of video memory that I can install in the expansion sockets for the onboard
Reply 18 of 21, by maxtherabbit
CuPid wrote on 2022-08-09, 22:10:
hello maxtherabbit, as suggested to Sphere478, can you please try with Sensor=0 in cpuz.ini ? thanks ! […]
hello maxtherabbit,
thanks !
I don't think I was using vintage edition, I'll have to go back and check
My system is running XP
