Reply 20 of 54, by rasz_pl
- l33t++
cyberluke wrote on 2022-08-18, 10:48:So the issue is that the faulty joystics beeps with short circuit error and have infinite resistance.
-resistance measurement doesnt beep
-infinite resistance is the opposite of short circuit
cyberluke wrote on 2022-08-18, 10:48:But it shows voltage change correctly.
is it one of those digital joysticks with actual electronics inside? open it up
cyberluke wrote on 2022-08-18, 10:48:Quickshot center is 59.2kOhm...minimum is 5 Ohm. Maximum is 135k Ohm.
thats more like it, proper joystick 😀
cyberluke wrote on 2022-08-18, 10:48:Measuring pin 1-3 (Joystick 1 X axis and +5V)
dont put any voltage on anything when measuring resistance, in this particular case it can only lead to bad measurements, but if you do this while checking motherboard or monitor you will fry something important
set multimeter on ohm range
put one lead of multimeter on pin 1
put second lead on pin 3
