First post, by DosFreak
Virtual PC 2007 on Windows 2000
The Virtual PC 2007 installer does not allow VPC 2007 to be installed on Windows 2000. Just like Windows Defender the fix is
simple. You simply have to remove the limitation from the installer. Read the following to fix this issue:
Download Microsoft Virtual PC 2007 32bit from here:
http://www.microsoft.com/downloads/details.as … &displaylang=en
You will also need Microsoft Orca:
Orca v3.1 (Inside of Microsoft's Installer SDK v3.1:
http://www.microsoft.com/downloads/details.as … 3E-40C0EC4F68E5
Once you have VPC 2007 and Orca downloaded start the VPC 2007 install.
Do not click on any buttons or do anything. Just leave the install sitting there.
Now go to your "C:\Documents and Settings\USERNAME\Local Settings\Temp"
You should see a file there named "Virtual_PC_2007_Install.msi". This is the file you want.
Copy this file to your "My Documents" folder.
Open "Virtual_PC_2007_Install.msi" with Orca.
On the left-hand side of the screen go to "CustomAction"
On the right-hand side of the screen choose "CA_CheckIfWeCanInstall" and press the delete key.
Go to File and then Save. Not Save As.
I didn't have a VHD with an OS on it handy (I stopped using VPC heavily long ago..guess why) but I did create a test VM and booted it just fine.
Have fun installing Vista on Windows 2000 using VPC 2007! 😀
Make your games work offline
Reply 3 of 7, by dh4rm4
Sure, but for many other people editing in general is a black art so apps like Resolver offer a simpler solution.
Reply 5 of 7, by franpa
anyways this news is archaic and was once posted on all teh internet news sites.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 6 of 7, by dh4rm4
that's a little redundant dude, this site is ALL about archaic releases...
This thread informs others aside from you. The internet isn't a competition.
Reply 7 of 7, by DosFreak
Not archaic to me. I was testing out 2000 compatibility for my list and noticed that VPC 2007 didn't work, so I removed the limitation from the installer. I didn't know if anyway had already done so or not. A quick search of the net only turned up 1 or 2 obscure comments on 1 or 2 blogs that didn't really confirm wether it worked or not.
If your referring to Defender then yes it was posted on alot of sites.
