First post, by halaxa
Hi, I'm real newbie with dosbox and I have a probelm. I need a specific program to be run in dosbox under linux kubuntu 7.04. It's a program for doctors, with database of patients called OBOLUS. When trying to insert new information about patient or when checking databases on startup, the program is extremely slow. Is maybe 50times slower. Option 'core' is set to 'dynamic'.
A Second problem is with charset. The program is Czech, so there are problems with special chars. Can someone help me with setting up the right charset? Or where this can be set?
Thanks a lot!
