Reply 2320 of 3035, by PD2JK
- Oldbie
Ok, my turn.
Ok, my turn.
Those are awesome looking cases. I'm curious as to what the ecokeys do?
Obijuan1983 wrote on 2022-09-07, 19:24:My recentrly restored-Retrobrighted PC's :)
These are terrific! They are all AT cases? They look almost brand new. :D
UMC UM8498: DX2-66 SX955 WB | 32MB FPM | GD5426 VLB | Win3.1/95
MVP3: 600MHz K6-III+ | 256MB SDRAM | MX440 AGP | 98SE/NT4
440BX: 1300MHz P!!!-S SL5XL | 384MB ECC Reg | Quadro FX500 AGP | XP SP3
chrismeyer6 wrote on 2022-09-07, 14:58:I'm curious as to what the ecokeys do?
It makes the PC go sleep. Like closing the panel on a laptop. A hardware hibernation button...
Here is a germen commercial featuring the ecokey https://www.youtube.com/watch?v=Su7YV01Ebi4
FCKGW-RHQQ2
DerBaum wrote on 2022-09-07, 20:05:chrismeyer6 wrote on 2022-09-07, 14:58:I'm curious as to what the ecokeys do?
That's a neat feature. Thanks
PD2JK wrote on 2022-09-07, 13:15:Ok, my turn.
Do you have both connected via KVM, or is it just for the picture? 😁
Obijuan1983 wrote on 2022-09-07, 19:24:My recentrly restored-Retrobrighted PC's 😀
Awesome. Too bad Retrobright can turn that black LCD into a beige CRT. 🤣
biohazardx9 wrote on 2022-07-06, 19:51:As requested my P II rig.
The Rage had a low profile bracket and I had no full spare so kinda made up one.
Hey! That's MY case. 😁
[Install Win95 like you were born in 1985!] on systems like this or this.
Cosmic wrote on 2022-09-07, 20:02:Obijuan1983 wrote on 2022-09-07, 19:24:My recentrly restored-Retrobrighted PC's 😀
These are terrific! They are all AT cases? They look almost brand new. 😁
The 3 at left are AT cases, the far right is a ATX with PII system inside.
Some photos from Retrobright, panels at first photo treated without taking photos before.You can see at the plastic base of one tower the difference and at drives...
Wow, those look great! Nice work!
"Okay, my torn." - Gru
Austin M1RC Pentium 100 2.9V 16MB RAM CL-GD7543 ES1688F 800X600 TFT 2GB SD (SD2IDE used since I don't have real drives) 1.44MB FDD
chrismeyer6 wrote on 2022-09-07, 20:09:DerBaum wrote on 2022-09-07, 20:05:chrismeyer6 wrote on 2022-09-07, 14:58:I'm curious as to what the ecokeys do?
Yep, as long as the mainboard has a SMI header to connect the button.
devius wrote on 2022-09-07, 20:35:PD2JK wrote on 2022-09-07, 13:15:Ok, my turn.
Invisible KVM switch. 😁
PD2JK wrote on 2022-09-08, 04:27:chrismeyer6 wrote on 2022-09-07, 20:09:That's a neat feature. Thanks
Do you still have the motherboard that came with the case ?
MMaximus wrote on 2022-09-08, 09:39:
Thanks mate, try to make bigger team!
The car is an Alfa 156 by the way!
PARKE wrote on 2022-09-08, 11:07:PD2JK wrote on 2022-09-08, 04:27:chrismeyer6 wrote on 2022-09-07, 20:09:That's a neat feature. Thanks
Story time, which is about the AT system. It was our first new computer at home. A few years later we sold it to someone who was handy with computers, which became a very good acquaintance after that.
10 years after that we were cleaning his shed and the system came to light again and I could have it. The FIC VA-501 was replaced by a PCPartner board. I know it came with the VA-501 because there was a sticker at the bottom.
There are not much mainboards with a SMI header for this 'Green Switch'...
TL;DR: Yes, after some swapping. 😁
Just one kinda crappy pic. Will have to do a proper photo shoot.
Specs:
Celeron 366Mhz
64MB PC66 SDRAM
Intel AL440LX (onboard Yamaha sound chip)
Samsung 4.3GB HDD
44x CDROM
Intel 10/100 PCI NIC
3DFX Voodoo 3000D
