I think i'll put my Akasa Vortexx Neo cooler on it. It fits mounting pins-wise, but will need a bit of a trim on a metal plate to sit properly avoiding the caps at the back.
Then there is the question of if it will adequately cover both the GPU die and what I assume to be the bridge chip under the GPU, as whoever designed the underside of the cooler decided it should have a trench milled out around the die contact zone.. that and the chips are in funny positions due to the addition of the bridge chip, so traditional coolers won't fit properly.
What I think i'll do is one of my typical hail-mary one-chance fixes, and I've ordered one of these 1mm 10x10cm sheets https://www.amazon.co.uk/Scratches-Attached-J … /dp/B098RTG29R/
I'll drill some holes so it fits over the mounting pins, then it'll act as a shim between the cooler and the two chip dies. Otherwise both would I think be only partially covered by the raised sections of the Vortexx copper plate.
I have some 1mm thermal pads which will then go on the ram under the cooler bringing the chips into thermal contact with the aluminium cooler plate surrounding the copper, which would be raised 1mm by the shim. I may also pop some in-between the copper cooler plate and the shim in the dipped section
It'll work (probably), and it should be better than the stock cooler. It just may look a little janky and run off molex power instead of the card power connector..
Thoughts on my cunning cooling plan? I must say i'm having more fun than I expected messing around with old graphics cards 😉
