Reply 22700 of 30433, by Shponglefan
- l33t
Did some more tinkering with the Tandy TL/2. Tried it again with the CM-11 monitor and this time it worked fine. No idea what the issue was originally, maybe just a loose cable?
I tried installing an XTIDE board to be able to use my CF card with it. Unfortunately this is where I ran into further trouble.
The CF card I had setup on my Tandy HX would only boot half the time in the TL/2. And then running a DIR, it would hang when trying to report back the disk space remaining. It's only a 32 MB card and works perfectly on the HX, so not sure what the issue is here.
I also ran into issues trying to boot from the floppy drive. Multiple DOS 5.0 disks wouldn't work and only a DOS 3.3 disk worked (and even that failed a couple times). Once I got the 3.3 disk working, I tried using another CF card (128MB). I was able to partition and format it, but then it wouldn't subsequently read the card at all.
So I'm not sure what the issue is. Do I have a defective XT-IDE board? Is it something else in the system?
I may try the XT-IDE board in my other Tandy SX system to at least confirm whether it is defective or not. At which point, I can then tear down the TL/2 for further inspection and testing.
