Reply 20 of 24, by Qbix
Qbix
Offline
DOSBox Author
- DOSBox Author
wrote:On a single cycle transfer issue the irq early (sb.dma.min) so the application can program a new transfer intime.
So that's the purpose of sb.dma.min 😀
That is how I read the code.
(because at the bottom you see that irq will be raised.)
Water flows down the stream
