First post, by Geri
I have recently repaired a damaged nVidia Quadro 4000 video card. (Fermi based card, released 12 years ago). I plan to use this card in my main pc for various reasons.
The card works fine, there is however a problem with temperatures. nVidia by default lets this card to reach 85c before it starts to ramp up the fans, and 95c before the fans fully throttle. This is obviously too hot. Under full load, the card becames so hot it hurts to touch the card.
-Obviously i have added new thermal paste on it, it only decreased the temperatures by like 1-2 degrees.
-I have tried to downvolt the card in videobios, as lowering the voltage will lower the temperatures as well. I have used nibitor to mod the bios. I modified every voltage down by 0.1v. Unfortunately, the card ignores the voltage settings. After flashing the bios with newest nvflash, it doesnt matters what settings i set, the voltage always stays factory stock default, and the card continues to run hot (i can set the clocks, that works, but that doesnt helps here).
-I have tried to hard-modify the pstate slots in the video bios as well. It doesnt seems to have any effect. (i will test it again later)
-I have tried to mod the fan settings in videobios, no luck either. All the settings are grey. I used third party software to change fan curves (max throttle above 85c), that worked, the card is now however very loud. Voltage settings would be better.
-Even with third party software, voltages canot be modified in the system on the fly.
-Fermi video bios editor doesnt works with the bios of this card.
-Tried random Quadro 4000 bioses. None of them helps.
Has anyone succesfully downvolted this particular card, or any other fermi based cards with vbios mod?
TitaniumGL the OpenGL to D3D wrapper:
http://users.atw.hu/titaniumgl/index.html
Reply 1 of 2, by Geri
Never mind. I figured out how to downvolt the card. Dump the original bios, in nibitor go to fermi voltage editor, open the bios, do not touch everything else because it will not work, only set all the perfmode voltage banks to 0 which downvolts the card to the pre-set value of 0.91v because nvidia forgot to lock this down as well. This gives a good ~6c decrease when measuring the temps on a given fixed fan speed. I didnt had to decrease the clock speeds and the card is stable. If your card becomes unstable from this, try to pull down from 475 to 405 in the last perf stage (multiple it by two for shader and readjust the bumped shader clock as well afterwards based on the third pmode), which is the medium 3d perf settings.
Reply 2 of 2, by Norrlandius
I am afraid I would mess setting up in NiBiTor.
Would it be possible for you to post your modded BIOS? Also did you BIOS flash the card with NvFlash?
