First post, by kaiser77_1982
- Newbie
Hi all!
I have just bought this card:
It is a Sis6326ASGP in PCI with Small PCB. Did you see before?
Cheers!
Hi all!
Cheers!
This is unusual choice of memory IC. SiS is 64bit datapath, halved to 32bits using this.
Does matter less since PCI bus chokes the maxiumum performance of the 6326, try it and see. But it is good on Pentium and Pentium MMX for DOS games.
Also H0 revision chipset means it should work properly.
Cheers,
Great Northern aka Canada.
pentiumspeed wrote on 2022-10-06, 23:59:Does matter less since PCI bus chokes the maxiumum performance of the 6326, try it and see.
Does it?
Well it's a H0 revision chip, so that is all good 😀
