First post, by pentiumspeed
Quick, reliable and can check on internal details like SMART not the ones that hides the drive behind chipset means I cannot use gsmartcontrol to read out the SMART attributes, I have seen this often but I need one that works with this utility. Reason for this, I have to use gsmartcontrol to diagnose hard drive issues for consoles. This is most important when I have to do this as all Xbox One (original, S and X) outputs no video if hard drive is corrupted or dying. Also no video output can happen on Xbox one S and X if their HDMI retimer IC is defective, hence need to confirm that hard drive is healthy or dying via SMART read out.
I also need to buy one or two so I can make custom external SSD boxes since USB 3.0 sticks had terrible write speeds. Takes 20 minutes to write a 6GB OSU1 folder of files to generic USB stick which I have to do nearly monthly due to microsoft version releases for the xbox one (original, S and X) stuff when I'm replacing their dying hard drives. Really annoying.
Thanks,
Cheers,
Great Northern aka Canada.
