First post, by Zeerex
Hey all.
I have run into this issue now with boards: Asus P5A, Gigabyte GA-5AX , multiple cases and power supplies.
So the primary symptom is that the computer boots up and works as it normally does. Then after power down, the power button doesn’t work. Pulling the power cord in the back doesn’t seem to fix it. There is only one fix: pull the power cord on the motherboard’s ATX 20 pin connector and reseat it. This usually fixes it but it’s obviously awful.
Anyone else experience this? The most common denominator is that all these are Aladdin 5s, ATX and modern power supplies.
Reply 1 of 3, by Sphere478
I haven’t had that issue before.
Multiple mobos, Have you tried multiple psus?
Does it happen with minimal cards and a different video card?
Sphere's PCB projects.
Reply 2 of 3, by Zeerex
Yes different video cards sometimes with a Voodoo and also others. Very similar to this thread where the P5A works fine until it doesn’t and then magically comes back to life. The poster may not have known the 20 pin reseat trick: Broken Asus P5A?
EDIT: I’ve not thoroughly isolated this issue I guess, but I’ve never encountered it with a P5A-B or any MVP3 board.
