First post, by Madao
dear folks
I got couple ISA card.
Two card is pearl. ELSA Winner 1000 ISA with S3 805i and ATI Mach32 ISA
But ROM is missed.
ELSA works again, with S3 801 ROM, but it is wrong... (freezed in graphics mode, because GenDac and DAC is not same. )
Thanks
matt
Reply 2 of 34, by Madao
This ROM doesn't work , because it is not split into even /odd.
I have split this ROM into even/odd and it works also not.
I got from member a dump of their Mach32 ISA VRAM. I got (only white) pictures with blinking cursor.
My Mach32 is DRAM-variant.
despite, thanks.
Reply 3 of 34, by Predator99
I had a similar issue and I remember it is not split into even/odd. The encoding is different. Have to search for the thread here...
FOund
BIOS for Diamond Stealth VRAM (S3 P86C911) needed
For this card its not split at all, full image in both sockets...
Reply 5 of 34, by RayeR
I found only mach64 ISA splitted 16k ROMs, no idea how far is it from mach32 but you may give a try...
BTW sometimes HW designer swapped data/address lines order to optimize PCB routing and then you need also transform the data...
Reply 6 of 34, by Madao
Thanks.
As I suspected, this ROM does not work.
Regards
matt
Reply 7 of 34, by mpe
ATI Graphics Ultra Pro:
Mine has ZIP VRAMs, but ROMs should work
Blog|NexGen 586|S4
Reply 9 of 34, by RayeR
BTW registration required for DL, maybe you could reupload it here for others...
Reply 10 of 34, by Madao
RayeR wrote on 2022-11-21, 16:17:
oh sorry..
thanks
Reply 11 of 34, by Madao
little repair story.
i got 40 card , mostly without ROM.
ELSA Winner 1000 ISA came also without ROM, you know already.
I got ROM dump and it works fine with text mode and vga mode fine.
But not VESA...
The attachment 1.png is no longer available
it is a card with ROM (sticker is wrong , rom dump is correct)
The attachment 2.png is no longer available
SMD elektrolytics failure.. very common failure
replaced by tantalum capacitor
The attachment 3.png is no longer available
failed VESA test
The attachment 4.png is no longer available
I think: ATT20C409 is not compatible with S3 SDAC. S3 SDAC came from dead S3 868 PCI card.
SOLDER IT !
The attachment 4a.png is no longer available
Card with S3 SDAC
it works now correct in VESA mode.. but not 100%
Reply 12 of 34, by Madao
VESA graphics fail : broken solder joint on S3 805i
resoldering-> success !
The attachment 5.png is no longer available
The attachment 6.png is no longer available
The attachment 7.png is no longer available
Washed and new Sticker..
I did make yet hope, someone save ROM from ATI Mach32 DRAM ISA.
Reply 14 of 34, by RayeR
Congrat to your repair. How did the S3 chip pin was bad? Was it bent/pulled from PCB pad by mechanical crash or just bad contact without any visible mechanical distortion?
Sometimes TQFP chips soldering went broken, probably due to PCB bend that cause pin lift above PCB pad a littel bit. I repaired friend's Matrox Millennium II that had bad joint on WRAM chip (I resolder all pins) that caused artifacts in VESA modes and memory errors was reported VMT test program...
Reply 15 of 34, by Madao
kixs wrote on 2022-11-22, 17:52:
Madao wrote on 2022-11-22, 17:36:
I have the card. How to save both ROMs via computer?
No EPROM-Programmer as TL866CS or similar ?
Other Solution : NSSI could dump VGA ROM
https://www.navsoft.cz/products.htm
It dump to file with size 32kb . (probably , it dump to file with 64kb size . )
Important: Your card mus look same as my with DIP DRAM, not ZIP-VRAM.
Reply 16 of 34, by Madao
RayeR wrote on 2022-11-22, 18:31:
yes, just a bad solder joint.
Not very rare failure on ELSA card..
I have fixing few ELSA card with resoldering on TQFP IC
How did i find failure: I have pressing on S3 805i and grahpics artifacts is gone.
Reply 17 of 34, by RayeR
Madao wrote on 2022-11-22, 18:34:
Yeah, sometimes it works, also for BGA chips...
Reply 18 of 34, by kixs
Madao wrote on 2022-11-22, 18:33:
No EPROM-Programmer as TL866CS or similar ? […]
I know about NSSI... here is the dump. It's 32KB only and I hope you can use it somehow.
This is my card:
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 19 of 34, by RayeR
Size and checksum is OK. Single image can be splitted to odd+even e.g. by Srecord tool:
https://manpages.ubuntu.com/manpages/bionic/m … examples.1.html
