Wasteland hangs
First post, by Snake Vargas
I can't seem to get Wasteland to play properly. I'm running it
on a Dell Optiplex GL620 (Pentium D 3.4Ghz), 2G memory, 80G hdd, ATI
Radeon X600 (256M RAM), XP SP2, Soundmax (or whatever is
default to Dell, probably onboard).
Game: Wasteland
Problem: I'll play the game for about 10 minutes or so & no matter
what I am doing, the system will lock up. I can be on the main
campaign map in the game, or in the character creation menu, or
anywhere & it the screen hangs. I've also slowed the CPU down
to see if that would help, but there were no changes.
Reproducibility: Always. 100%.
Sound mode used: Default to Dosbox
Video mode: Default XP (1024x768 res, 16-bit)
DOSBox version: 0.70.
Please help or offer advice.
Thanks,
Snake.
Reply 1 of 3, by Snake Vargas
I think I've resolved this issue. I followed the README.TXT for game hangs. I think it's the sound settings. Perhaps Wasteland only likes it if you have a PC Speaker. I simply ran every command given in the Readme guide for the game hang & so far so good.
Reply 2 of 3, by wd
Rank DOSBox Author
DOSBox Author
Hm so it only occurs with soundblaster selected? What settings did
you choose exactly?
Any idea when it happens, or is it random and just happens after
a while of gameplay?
Reply 3 of 3, by Snake Vargas
Hi WD,
It appeared to crash using the default settings in DOSbox. It seemed to
happen after about 10 minutes of play. I think it was occurring when doing
something such as transitioning from the area map to a town map or going
from one of the maps to an encounter. Wasteland would hang at that
point & not way out of it.
I never saw the error again after applying all the settings mentioned
in the troubleshooting a game hang section of the DOSbox readme.
