Reply 900 of 1177, by red-ray
- l33t
GL1zdA wrote on 2022-10-24, 21:26:AIDA64 reported my 900 MHz Xeon running at 5x180 MHz
It's a bug in AIDA64, I expect its only using 4 bits when it should be using 5 bits. It's nothing to do with the MB jumper settings.
The multiplier comes from MSR 0000002A (EBL_CR_POWERON) and for Coppermine or Cascades CPUs >= stepping 0x03 it's 5-bit rather than a 4-bit value with x9.0 being 0x10. To convert this value to the multiplier SIV has a 32 entry vector with 0x00 -> x5.0 and 0x10 -> x9.0.
I recall SIV also having an issue before I fixed it, the SIV bugette was always using a 5-bit value for Cascades.
